Sirius Voice Command Update File Available at SYNCMyRide.com
Discussion in 'Ford Professional Forum' started by HARLEY6LF250SDU, Jun 13, 2011.
  1. HARLEY6LF250SDU
    HARLEY6LF250SDU FRF Supporting Member Supporting Member
    56
    1,583
    154
    Sep 8, 2010
    St Louis, MO
    Sirius Voice Command Update File Available at SYNCMyRide.com (6/13)
    The following message was posted to SYNC | Change Songs, Make Phone Calls, Get Directions - All Using Your Voice | Ford.com on June 1, 2011:
    'In regards to the incorrect Sirius voice commands concern, we now have a user-installed file that you can download to a USB (flash or thumb) drive. To download the Sirius Voice Command Update file, please follow the steps below:
    Download the Sirius Voice Command Update file, which can be found here: http://www.syncmyride.com/siriuschannelnamepatch/BT4T-14D546-GA.zip
    When the download is complete, unzip the file to a flash drive. NOTE: Be sure to unzip the file directly onto the flash drive, not into an existing folder.
    To properly run the installation on your vehicle, please follow the instructions on the ReadMe.txt which can be found on the zip file. This is a temporary solution for this concern; I will post an update once a more permanent solution is in place.
    NOTE: This user-installed file can be used for 2011 Ford Edge and Explorer, Lincoln MKX, and 2012 Ford Focus vehicles exhibiting the Sirius voice command concern.'
  2. swoop1156
    swoop1156 FRF Addict
    3,291
    285
    Dec 14, 2010
    Honolulu, Hawaii
    I don't have any issues with mine, so I guess I won't need this. :)
  3. CineSLR
    CineSLR Roaming Shutterbug
    1,539
    449
    Mar 17, 2011
    New Orleans, LA
    is this due to the new channel lineup?
  4. BOJANGLES
    BOJANGLES <span style="color: red;"><b>Administrator</b></sp
    6,524
    1,042
    Jul 6, 2010
    Chihuahuan Desert (EPTX)
    It's like you stole the question right out of my mid and posted it for me :)
  5. TheJoker
    TheJoker FRF Addict
    52
    4,126
    3,288
    Dec 6, 2010
    N. E. Massachusetts
    I've never tried voice commands to control Sirius. So, I haven't had any issues. Has anyone else had problems?
  6. Crosstx
    Crosstx Full Access Member
    512
    8
    Feb 13, 2011
    Midland TX
    Dude
    There is soo many handsfree functions i will never remember to use.
    I was bored the other night and played with the voice command on nav while driving. Its a ton of steps to get your destination in but it works pretty darn good.
  7. iceman302
    iceman302 Full Throttle OG
    41
    1,423
    43
    Nov 3, 2010
    El Dorado Hills, CA
    That's the only way I use the NAV. You can do it while driving. I hate sitting there parked while you type in a destination.
Share This Page
