Sight grinding from front right tire
Discussion in 'Ford Raptor Problems and Questions Forum' started by whtrapta, Sep 9, 2013.
  1. whtrapta
    whtrapta Ostrich Wrangler
    27
    5,489
    911
    Jan 17, 2011
    Bolivar/Springfield, MO
    My truck started making a slight grinding noise from the front right tire. Sounds like it could be the hub maybe? Anyone know or have experience with this?
  2. blood
    blood FRF Supporting Member Supporting Member
    1,296
    284
    Jan 28, 2012
    when turning or all the time?
  3. pat'sRAPTOR
    pat'sRAPTOR FRF Addict
    31
    5,590
    2,053
    Jul 17, 2011
    Everywhere
    Hmm that's odd. Have you taken te tire off to check your brake pads and rotors. It could be the hub bearings it's easy to pull the hub off and look and since it'll be off you could replace the bearings lol
  4. Yukon Joe
    Yukon Joe FRF Addict
    40
    18,308
    11,562
    Nov 16, 2011
    Oak Island, NC
  5. whtrapta
    27
    5,489
    911
    Jan 17, 2011
    How easy/hard is it to replace the wheel bearing?
  6. pat'sRAPTOR
    31
    5,590
    2,053
    Jul 17, 2011
    Everywhere
    Well the bearings I think are pressed in so that might be the hardest part of it all. Everything else is easy to take off
  7. Steele16
    Steele16 Full Access Member
    786
    474
    Jan 5, 2012
    Centralia, WA
    I destroyed a wheel bearing and it made more sense to replace the hub
  8. pirate air
    pirate air will plunder your booty Supporting Member
    4,253
    1,329
    Jul 11, 2010
    Trying replace just the bearings is nearly impossible because the ford hubs are a sealed one piece design. The hub assemblies are fairly easy to replace. Pull the tire, brake caliper, brake rotor off. Remove the wheel speed sensor from the hub housing held in with a allen head bolt. Remove the cover and stub shaft nut that holds the cv axle in the hub. You'll probably have to tap on the cv snub with a hammer to free it so it will slide out when you remove the hub. Remove the four hub bolts from the back of the knuckle and it should pop free with a hammer and some penetrating lube if needed. It helps to remove the outer tie rod end so that you can swing the suspensions forward and back to get to all the bolts.
    Generally a hub bearing is easy to diagnos by loading the suspect side of the vehicle up and listening to see if the noise gets worse. So, if its right side bearing, make a some what long hard left turn to load the right side and see if the noise gets worse. If so 99% time it's a wheel bearing/hub.
  9. pat'sRAPTOR
    31
    5,590
    2,053
    Jul 17, 2011
    Everywhere
    Yea and hubs depending on what you get range from $70-180 and the mastercraft hubs are about $260 a hub. They do sell bearings but like pirate said its hard to replace. A new bearing goes for about $40-60
  10. whtrapta
    27
    5,489
    911
    Jan 17, 2011
    The truck goes to ford today. ESP is covering the fix. Dealer says it's not a bearing because that would be a constant roar, I have a more pulsing grind. Think of a cricket. It's expected to be something in the 4wd
Share This Page
