1Wolf
Seems the ginormous antenna on this thing won't quite clear my garage door and thwacks it good each time. At first I figured I'd just go slow and be careful but its getting old.
For those with a similar problem, what did you do? Did you replace the factory one or cut it down?
If you replaced the factory one, what did you replace it with and how's it working for you? I prefer not to lose any reception and I really don't want it "whistling" on the highway.
After searching the forums here and some googling, it seems the CravenSpeed Stubby is popular and often recommended but I don't particularly care for a stubby.
Or, if its the later and you cut it down...any advice on how long you cut it or the process you used? I've never cut down an antenna before.
Does Ford offer a factory antenna that might be a bit shorter?
Thanks!
Thanks!
