Shackles
MTF
Celebration, Florida
Yup
But now that I took a third look at the shackle you have on there, they look pretty close to the bed.
You have the 1" extended already.
Your top bolt is right at the top of the frame rail.
Here's a picture of the stock shackle.
mpk1996
Next question, if I order extended Camburg’s will they work with Icon springs?
Yes. The camburg drop shackles will work with the icons. That’s what I run. Stock shocks. The std length camburgs dont work
MTF
Icons have a half military warp around the rear eyelet. OK
And on Icons website they are using the stock OEM shackle.
I guess this would have to be brought up to Camburg attention so the can trim the stock length shackles to work with Icons.
They probably know already.
I have the Deavers +2 and the Tig welded stock length Camburg.
