SDHQ
We have been working closely with one of our vendors to further develop the Ford Raptor Alignment Cam Kit and this is the result!
These all new Raptor alignment cam kits will now be available with eccentric grade 10.9 metric bolts! This means you will have a MUCH stronger lower control arm bolt that you will not need to torque to the same extreme toque specs as the stock bolts.
Over time these extreme torque specs can cause the bolts to stretch and weaken.
Our standard alignment cam kit will still be available for those trucks that see mild off-road use. But, for those that truly push your truck to it's limit these are a great upgrade.
These new alignment cam kits will work with our Lower Control Arm Doubler Plates as well!
https://sdhqoffroad.com/collections...ptor-alignment-cam-kit?variant=12250095812643
These will fit the 10+ F-150's and Raptors
