SDHQ Front Long Travel Suspension System...
SDHQ
GILBERT, AZ
Finally... We are ready to go...
Over 85 Feet Of TIG Welding In This System
CAD Engineered, SDHQ Tested, Tuned, Tortured & Approved!
4130 Chromoly Construction
Signature SDHQ Fit & Finish
16.5” Of Clean, Usable Travel
2” Wider Per Side
Retains Stock Coil Bucket W/ Minimum Amount Of Cutting – Easy To Return To Stock
Fully Boxed & Internally Gusseted
Fully TIG Welded
Heimed Upper Arms
Delrin Lower Pivots
1” Upper Uniballs
1.5” Lower Uniball
Can Run Stock Wheels/Tires
Fully Machined 4130 Tie Rods
Full Heim Steering
More info & pics- Raptor long travel by SDHQ
Aaron
Meme Corps Commandant
WA
At the risk of sounding stupid...is this a bolt on or weld on system as far as the shock mounts? I ask because it looked like it might be bolt on.
SDHQ
SDHQ
GILBERT, AZ
No stupid questions.. The upper mount is a bolt on with the exception of 2 - 3/4" spots that get welded.
Aaron
WA
Cool! Thanks for the fast reply too!
Donk74
Peoria, IL
Sweet!!!
Any idea how much longer till your long travel, cantilever rear system will be available? Can't neglect the rear end.
Also, any plan to offer shock packages from anybody other than Icon? Nothing against Icon, just curious.
SDHQ
SDHQ
GILBERT, AZ
Yup!
Sweet!!!
At this time the cantilever rear set up is only offered as an install @ SDHQ.. The set up of the rear is critical and we have not yet worked on a jig to offer with the kit for another shop / installer to use. However, we are finalizing our sprung under "kit" that will be for sale shortly.
Our test mule is running the lt kit w/ our rear set up and it sucks up the whoops nicely. With our set up you are gaining 1.5" of rear wheel travel and tons more wheel control... Deavers, SDHQ Hydraulic bumps & Icon 3.0's
No plans for other shocks through us at the moment. We do offer the kit with out our upper mount so if a shop / end user wanted to go with a different set up it would just be a matter of building an upper mount specific for those shocks.
ktm505sx
Could you pm me a final price of the LTS with 2.5 suspension
What else is requied to run the kit?
Extended brakes lines?
Wider fenders?
Do i need shock mount?
Do i need longer front axle too?
Thanks
