btkeenan
Went camping up in the mountains recently and did not have any service while out and about. We bought some basic FRS Motorola radios a while back but had some issues receiving reliable communications with them so opted to get my GMRS license and a more powerful radio. Given we primarily use this truck for any camping/over landing expeditions, it seemed like a natural choice to find a kit that was tailored to the raptors. Looked into VHF and CB but this seemed like a good middle ground for the crew that I would usually do any off-roading with. The kit itself I picked up from Matt at TSP Parts who hooked it up. Service and shipping was quick and easy which can’t be taken as a given nowadays. I opted for the G1 waterproof as it had options for channels and other details on the handset which should be useful as the radio will be mounted in the center console. Also ordered an external speaker and a stealth antenna to complete the kit.
Now for the install, I read through their pdf which is a bit.... lacking and couldn’t find much, if any info online which was strange considering how much info there is about if 37s will fit or if the truck will fit through a Starbucks drive thru, so figured I'd document my notes on the install process for anyone else that is looking at buying/installing this for their truck so it's less of a IYKYK.
Additional Tools/Parts required:
-8mm socket
-10mm socket
-Ratchet
-Plastic Pry tools
-Light
-Metal clothes hanger for fishing wire
-Zip ties
-Weather pack connectors (I used these which worked fine but the instructions are backwards and have you mount the male pin in the female housing)
-14 AWG wire
-Barrel wire crimper
-Butt connectors
-Replacement sync 3 surround
Antenna Mount
Bit of a PITA to install. The instructions are 0 help as it doesn’t even go into what to do for a Gen 1. The kit includes a drivers side mount and a generic mount for other GMC/Chevy/Ford products but doesn’t look to be compatible for the raptor. As a preventative measure, I taped off the edges of the hood and fender with painters tape to protect the paint near the installation area. The bracket is decently thick gauge bent metal so snaking it into the final position with the hood halfway down is channeling but doable. Once it’s in the general area it should be, you can loosen the two 10mm fasteners holding the hood to the chassis. The weight of the hood will provide tension to the fasteners as you loosen them and the bracket will want to shift towards the cab. I did not remove them fully but did loosen them enough to allow for the feet of the mounting bracket to slot between the washer and the frame. I found it easier to get the rear feet in place and then pivot the bracket around to get the front in but because space is limited it’s tricky. Also, because the hood is providing tension, you have to push the underside of the hood up and back to force the hood bracket down and forward. Now you’ll want to grab your antenna cable and run that on the fender side underneath the bracket and up the edge to where the hole is located. You can thread it in place or just leave it hanging for now. Unfortunately, the end is too large to go through the slot between the bracket and cowl once the bracket is in place (ask me how I know). Once you do that, I snugged one of the fasteners up so that I could test fit the placement relative to the hood. For the back one, I pulled the bracket away from the engine which pulls the cowl slightly and then at the same time pushed the hood towards the engine. This took me a while to get just right to make sure the hood didn’t rub on the bracket. IMO, the bracket should have been better designed to not allow for that eventuality because on a test fit, it took a chunk out of the corner of my hood which sucks. The final position of the hood and bracket is so close you could probably only fit a piece of paper between the two. These tolerances on a truck that is meant to go off-road hard seems a bit silly. Once in place though it looks sleek and out of the way which is what I was looking to do.
Power
As I was doing research for this project, I came across some cool extension pigtails for the aux and pass through wiring at the passenger footwell. I think the pricing they were charging is a bit much so I opted to buy my own weather pack connectors, crimper and wire to make my own (I made 20 for about $40). Took about an hour to do all of them and now hopefully can easily connect any future accessories to the truck. So the only issue with hooking these up is the lack of room in that area and how short the cables are from the factory. My aux 1/2 are taken by lights and I only needed 15A as denoted by the radio so aux 3 was perfect (reference this thread for more AUX info). From everything I have read online and even from the instructions for radios, they say to plug directly to the posts on the battery but given aux 3 is a 15A switch with integrated relays, I decided to send it and hook up the G1 to this and then grounded it to a bolt on bare chassis. This conveniently allows the power to be tied to the vehicle power when the aux is on so no worries about the radio being left on when the truck is off. I did some preliminary testing up in the mountains near my house and everything works as expected. Powers up with the flick of the switch and channels come in loud and clear so I guess time will tell. If this ends up being an issue long term, I now have the option of quickly and easily disconnecting the weather pack connector and running it to a passthrough connector and to the battery directly but for now this will suffice.
Cab Wiring
Now to fish the wiring through to the cab, I saw a wiring harness grommet in the firewall which had a little nipple on the perimeter of it. Checked underneath the steering column and sure enough it’s a cavity that could accommodate some cabling. I pierced it with an xacto knife and then used some scissors to cut from the middle to the outer edge so I could slot the cable into the channel and pull it through since the head of the antenna cable is too large for pulling it through. Once in place, pull/push the grommet into place from either side otherwise you’ll be feeling heat at your legs from the engine while driving. To get the rest of the antenna cable to the center console, I routed it below the steering column where the factory wiring harness is and along the side of the middle shift tunnel. The lower forward most panel has a few tabs and comes off rather easily which gives you some room to run the wiring while tucking it under the plastic. I found that there are 8mm fasteners on the front and back lower portions of the console on each side. If you undo all 4 of them, you have enough room to prop up the console with a 2x4 which allows you to fish wiring into the center console area without having to do any irreversible modifications to the sides of the center console. I removed the USB hub that is press fit into place and used a metal coat hanger to fish the antenna from the drivers side and then was able to drop the power cables on the passengers side through the same area. You are then able to run the power cabled along the passenger side center console and up below where the glovebox is along the wiring harness through that area and then to the upfitter switch area. So I am a fan of installations that are reversible for when things change and I want to revert things back to stock. Got to thinking about how to make these wires look more OEM and remembered during the install of SYNC 3, that the USB hub came in 2 pieces because they have a few configurations of those hubs. So, I opted to get a new plastic surround and drilled some holes on either side for the power and antenna wires. Replacement part appears to be an OE Ford one that had the FoMoCo logo ground off which is fine by me. I wanted to mount some normal wire grommets into the two new holes but couldn't quite get the fitment right with the cables and the grommets themselves so I went with a 3/8 T style grommet which I was able to cut and then press fit into place. The antenna dropped right into place but the two power wires had some finagling to get it to seat properly.
Antenna Routing
Center Console
SYNC Surround
Final Mounting
Hook the power, antenna and accessory ports up and then slot the entire assembly into place. I used a small strip of mastic tape on the bracket on both sides to help with vibration as well as to not leave a witness mark when tightening the thumb screw into the plastic. I also bought 2 rocker switch plugs to plug the two vacant holes which I think should be included in this kit. I saw a clever mounting solution for the external speaker here which I may copy but I have also looked at running a ram mount to the headrest pole, cup holder mount or mounting it to the builtright industries dash mount but TBD.
Final thoughts
While targeted as a plug and play setup for the raptor, it *is* just. People like to hate on the rugged radio stuff being rebranded as cheaper China garbage without using the gear and honestly it feels solidly built and easy to use without the fuss right out of the box. That coupled with Matt at TSP Parts making the purchasing and support experience easy seems like a win in my book. Will need to use it out in the field more but am happy enough with this kit and it should suit my purposes well, just mind the hood.
-8mm socket
-10mm socket
-Ratchet
-Plastic Pry tools
-Light
-Zip ties
-14 AWG wire
-Butt connectors
Antenna Mount
Power
Cab Wiring
Antenna Routing
Center Console
SYNC Surround
Final Mounting
Final thoughts
