RSI Smartcap Suggested Maintenance - Keep Your Cap Happy and Healthy
OffroadAlliance.com
Boston, MA
Something no one ever seems to talk about on the forums is routine maintenance for their RSI Smartcaps so we'd like to start a thread here just to get the information out there. We want to ensure that everyone’s cap lasts the test of time and performs exactly as it should for as long as you need it to.
It’s great to get into a routine practice of checking your assembly block bolts every 3-4 months to ensure they’re at the proper tightness. Go around to each one and just give it half a turn to retighten the bolt. If you’ve been experiencing any kind of leak or foam peeling out, this should help fix your issues. Anyone who purchased a Smartcap in 2020 and has not done this yet should be due to check on the bolts to make sure everything is as it should be.
As well as checking on your assembly block bolts, lock barrels should be lubricated regularly. This ensures the dust cover plate and tumblers are kept in good order. It also makes sure nothing gets bogged down with dirt and grime and stays working nice and smooth.
