RPG tie rods
BroncoDavid
Has anyone ran into problems installing RPG TIE RODS. I just install new uca's, shocks, eibach springs, lower ball joints and the RPG tie rods.
Issue I'm having is the tie rod isn't articulating fully and it doesn't let the heim join line up with the clevis unless some one puts some weight on the truck to lower the steering rack....
I got in contact with RPG and they are sending me new knuckle heim joints.
The picture shows the tie rod maxed out on travel hight
Antho
Looks like its hitting the misalignment spacer. Hopefully they are also sending the correct size spacer.
Bozz
Royal Smart A$$
Nashville, TN
I have all the parts to redo my entire front suspension. I researched the everliving kr@p out of it. Was wanting new UCA's with heims, but after reading a TON, decided to go with OEM UCA's. Apparently heims need constant looking after and replacement after a year or two. I didn't want to have any issues, so I skipped them. Those billet UCA's looked darn nice, though.
B
BroncoDavid
Yeah I understand they need a lot of maintenance but I've never had any on any of my vehicles so I figured why not try them out on the Raptor lol....and I had hell pushing in these APEX lower ball joints...I tore up the ball joint press
Roush2568
FRF is not for the weak
Colorado
I lube everything up every 5K miles when I change the oil on the truck, I also lube my built front end.
Dudebrodude
Orange County, CA
Unless you're hammering your truck in the dirt for thousands of miles per year, UCA uniballs and heims are usually a non issue. I had my previous UCA on my TRX for three years and all heims were still tight. That said, there are a few companies making ball joint billet UCA's now for people that want the corrected geometry without the maintenance.
W0n70n
C Springs, CO
As long as the new heims are going to come with new misalignment spacers, I don't think the heim is the issue here, it looks like the bottom of the misalignment spacer is machined incorrectly.
101,284
60,415
Gerth
