RPG Recovery Rack and Pro Eagle Jack Fitment
kickingaz
New River, AZ
Has anyone installed the Pro Eagle 2 Ton Big Wheel jack in the RPG Recovery Rack? Although the mount will fit between the rails, the wheels of the jack are too wide to fit. I can move the jack towards the back of the truck, but then the locking pin interferes with the rails, and it have to be moved even farther back. My thought is fab the mount vertically and have the jack sit behind the fuel jugs to take less room. Anyone else do something similar or any other thoughts? Thanks. IMG_7551D.jpeg
HOLLYWOOD 1
2Sun AZ
Something looks "off" with the rack? I have an RPG rack, and it's not like that at all. Mine has 2 holes with a loop for straps like yours, but wider? The bottom is much wider, with a panel. I bolted the jack carrier to it.
kickingaz
kickingaz
New River, AZ
Do you have the later model rack with the cooler/fuel jug top rack (one compartment) or the older style with the two fuel jug compartments? That may be a difference from the first ones made to the current one available.
HOLLYWOOD 1
2Sun AZ
I have the rack with the one top compartment. I store 2 gas cans in it. As I mentioned, it also has the bottom shelf too. I don't have my truck at the moment, or I would send you some close up pics, sorry. My rack is definitely wider, I tried to show that.
