RPG air bump stop and bed liner
zx14teryx
i know this may be a stupid question, but sometimes my OCD gets the best of me.
to install the cross bar, you have to lift the bed a bit, I have the factory sprayed in liner, for those of you that have done it, how did you not make a mess of the bed bolts that are sprayed in?
M_NorthRaptor
British Columbia, Canada
I used a heat gun to soften the material. Held it about 8inches away. Then slowly started to cut around the bolt with a fresh utility knife. And you have to make sure you get all the material from inside the torque plus hole otherwise you won't get a good grip when unbolting.
I've heard guys just cutting with a knife and no issue. Patience, slow and steady.
Z
zx14teryx
What did you put on it once completed?
flynford
San Jose, CA
I haven't looked at a F150 that has the spray-on type liner from the factory in a long while but I don't believe Ford or any professional liner company would spray over the bed mount bolts. I know I had Linex done on a few trucks over the years and they never sprayed over the bed bolts.
Anyway, you don't need to loosen the bed to install that crossbar. Perhaps I was lucky but do recall it was a little snug and a sand-mallet made it easier to adjust it to allow me to pop-in the bolts.
sixshooter_45
Arnold
Ford actually does spray the bolt heads which is why I recommend and went with Line-X because they do it correctly.
Z
zx14teryx
On keep it dirty video, he had to lift the bed about 1/2”
richnot
Central New Jersey
That is the same with my 18, they did a great job from the factory if that is really where is is sprayed in.
I would use a heat gun and knife and if you need to just reseal it put some black RTV sealer under the head of the bolt and wipe away the excess
Dustan
Boulder Colorado
I installed SVC’s kit and didn’t have to lift the bed. I did remove the bed bolts for a chase rack with the cut and peel method. It comes off fairly easy, the bolts are treated and shouldn’t rust
