Roush s/c low power on dyno
Discussion in 'Ford Raptor Engine Discussion and Performance Mods' started by RubyRedRaptor, Feb 12, 2016.
Sponsored By: GotExhaust
  1. RubyRedRaptor
    RubyRedRaptor Member
    5
    Feb 12, 2016
    Sydney Australia
    Hi,
    I installed a phase 2 roush sc kit to my 2014 over Xmas.
    I didn't have access to ford scan tool to load the roush tune, so I opted for a custom team jdm tune I could load with my SCT.
    I was a bit disappointed with the performance gain with the s/c.
    I took it to a dyno to give it a few runs, more just to check tune was safe.
    I had max power at only 372hp? At 6.7psi.
    Is this normal? Team jdm claim 500rwhp from there kit/tune.
    I'm not sure of what psi they should run at but assumed it would be 8psi.
    Does anyone have any idea of what could be wrong?
    Mechanical or tune?
    Could the bypass be malfunctioning?
    I've attached the last dyno sheet.
    This is a 93 oct tune too
    Please help
  2. torrin
    torrin Full Access Member
    401
    189
    Jun 26, 2012
    Nashville, TN
    What else do you have on it beyond the SC? Did you add exhaust, CAI, etc? What else have you done to let it breath better?
  3. RubyRedRaptor
    5
    Feb 12, 2016
    Sydney Australia
    Roush cat back
    Roush cai
    Everything that came with there phase 2 off-road pack
  4. mike.s
    mike.s Full Access Member
    974
    634
    May 12, 2012
    Definitely seems low. I had 330 stock and 450 when my Whipple was first installed. With JDM tune, I was around 485. Roush should be around the same.
  5. RubyRedRaptor
    5
    Feb 12, 2016
    Sydney Australia
    Yeah
    So why is the question
    What boost is stock for the 75mm pulley?
  6. mike.s
    974
    634
    May 12, 2012
    Is the line on the bottom your before dyno? Looks like around 240.
  7. RubyRedRaptor
    5
    Feb 12, 2016
    Sydney Australia
    No that's the psi graph
  8. jokerz
    jokerz Full Access Member
    247
    169
    Dec 13, 2015
    Are you sure it's just not the Dyno selection.
    I have had customers Dyno there cars on two different types of Dynos and one Dyno read 806 on a Dyno pac and then went to a dynojet and it read 706.
  9. MTF
    MTF FRF Addict
    3,407
    845
    Nov 27, 2010
    NYC
    They didn't do a base run before mods?
    Boost can vary by 1 to 2 lbs. depending on exhaust and SC pulley size.
    But 8 is the baseline.
    To me, it seems they did not setup the parameters correctly.
    Most dyno shops always display HP & Torque with a boost graph on the bottom for superchargers.
    You may want to invest in a OBD11 adapter and a phone app.
    Our PCM is capable of displaying HP & Torque at the flywheel or rear wheels and Boost plus a lot more.
    Most importantly the fuel trims!!! Short & Long
    This way you'll know if its installed correctly.
  10. jokerz
    247
    169
    Dec 13, 2015
    Normal Dyno graph for reference
    MTF likes this.
Share This Page
