RexusRaptor
Pasadena, CA
2020 Raptor with 2600miles so far. Ive noticed both on street and on the freeway that it rides rough, meaning I feel every bump on the street and the freeways. It is really noticeable on the concrete freeways of Los Angeles. Every seam is felt. Not sure if it’s just me or I’m assuming that it should ride smoother than it does. Stock suspension with Fox Live Valve. I’m running 37 PSI all around. I had my tires down to 35 front and 29 rear and it didn’t really help, also tpms was on with that low of pressure.
Ideas, comments, suggestions welcome
jzweedyk
Moab/Winter Travel/Summer Travel
If there is something wrong with the shock "system" they will default to "hard" setting. Take it to the dealer to check it out, or get in touch with Fox. It is possible that one of the plugs on the shocks did not get plugged in at the factory.
RPG
Orange County
Try a reset. Foot off brake, push start button, wait a few and push again to shut down. Worth a try
Try that first.. If it doesnt feel better, try disconnecting the battery for 30 minutes. If its still the same, bring it to the dealer.
K223
Florida
36/34 is what many run on the street. No weight out back and you get a much smaller contact patch in the rear if your air these tires up too much. Not to mention hobbling all over bumps on the street. Get much past 36/37 up front and the ride firms up and doesn’t take bumps well on-road.
Try the shock reset like mentioned. It’s worked for others. Otherwise the truck should not ride like that.
Donovan
DC
" Foot off brake, push start button, wait a few and push again to shut down."
