***ROGUE RACING #0001 2015 F150 Stage 12***
Jimbo
Mad Frog Mattis
IL
***ROGUE RACING 2015 F150 Stage 16***
FOR SALE
ROGUE RACING
2015 F150 5.0L V8 Supercharged
Stage 16 RAPTOR KILLER
Located in Henderson, NV
$59,999!!!!
PM me with any questions
ONE OF A KIND F150.
This vehicle is for sale by owner, Rogue Racing, Inc. based in Henderson Nevada. We are a Ford specialty design and fabrication shop and have built a one-of-a-kind F150 that would run circles around any Raptor or F150 anywhere. We are ramping up for our next build and this truck is ready for a new home. Please visit the website link for more information. Some of the unique features are listed below:
Front Suspension Features
Horizontal Uniball Upper Control Arms
7/8" FK JMXT Heims
1" FK WSSXT Uni-balls
Double Pocket Lower Control Arm
1.5" FK WSSXT Uni-Balls
Flutted Bushing Mount
Double Shear Tie Rods
7075 Aluminum
7000 Series Aluminum Alloys Are The Stongest Made
7/8" JMXT Heims At Spindle
Stainless Steel Heat Treated Clevis At Steering Rack
Mil Spec Hardened Steering Rack Bolt
Coilover Shock Tower - Relocated Outside Upper Control Arm
Holds King 2.5 Coilovers w/ Remote Resivor & Dampening Adjuster
Bypass Shock
KING 3.0 2 Tube Bypass Shocks
Located In OEM Coilover Location
Correct Length Half Shafts
+3.5" Heavy Duty CV Shafts
Limit Straps
2" Rogue Racing 4 Ply Adjustable Limit Straps
Slot Delete Alignment Kit
Allows For Precision Alignment via Upper Control Arms
Keeps Lower Control Arm "Centered" In Crossmemeber
Front Lower Cross Member w/ Bump Stop Cans
3x Stronger Than The OEM Crossmember
Integrated Bump Stops For Additional Suspension Dampening
Supports KING 2.5 Air Bump Stops
3/16" Laser Cut
CAD Designed
Cutting & Welding Required
XRP Brake Lines (Optional)
Minimal Volumetric Expansion Under Hard Braking Situations
Rear Suspension Features
3 Piece Bolt On Bed Cage w/ Bump Stop Cans & Frame Gusset Supports
No More Bent Frames
Prevents Bottom Out Feeling
Weld On Shock Mounts at Rear Housing
Leaf Perch Relocation Brackets
Increases Suspension Cycling
Leaf Spring Shackles
Sprung Under Leaf Pack
Limit Straps
KING 3.5 Bypass w/ 3 Tube Piggyback Reservoir Shock Absorbers
KING 2.5 Bump Stops
Rear Suspension Options
Currie Full Floating Rear End
XRP Brake Lines
Accessories
Rogue Racing Single or Double In Bed Spare Tire Mount
Tailgate Bed Support Brackets
2 Piece Intercooler & Custom Reservoir Tank
Performance Add-ons
Whipple Supercharge w/ Shelby Dyno Tune 750hp. 620hp @ Rear Wheels
Stainless Works Headers
Stainless Works Exhaust w/ High Flow Cats
Appearance
Fiberworks Front Fenders & Rear Bedsides
Rogue Racing Headlight Support Gussets
Rogue Racing Bedside Support Gussets
Rogue Racing Modular 3 Piece Front Bumper (Required Frame Horn Chop)
Rogue Racing Dovetail Rear bumper w/ Integrated Hitch (Requires OEM Hitch Removal)
