Rim size for Gen 3 stock tire
JD NYC
new york
Looking to replace the stock rims and use the stock tires on the Gen 3 , looking for a all black deep dish look ,need to know the exact size / off set that fits the stock tire. My opinion the truck definitely rides better with the stock tires , don’t pressure yourself to change tires like I did for looks.
combatninja
offset has absolutely nothing to do with a tire fitting or not. It is diameter, obviously, and width. Just go to tirerack.com and search for your exact spec KO2 and look at the specs. You're gonna see a stat called 'measured rim width' or somesuch. There is your answer.
New recaros
Colorado
Try the different calculators on this site.
catinthehat85
Socal
If I’m understanding your question correctly, it’s been proven rim widths between 8.5 and 9.5 will work best with the BFG KO2s, with offset up to 0mm (0 for 8.5 rim width, +12 for 9.5 is the same thing) without fear of trimming or fender issues under compression.
