Rim change
Discussion in 'Ford F-150 Raptor General Discussions [GEN 2]' started by MAJ01, Mar 18, 2017.
  1. MAJ01
    MAJ01 Member
    Mar 18, 2017
    New to forum. I was thinking about a wheel upgrade to Sota AWOL Anthra-Kote. They are beautiful rims. Smallest they make is 20x9 same hub bore 87 and bolt pattern. I think I would need to go with 35 inch tires. My question is does anyone know if there would have to be any modification to the suspension for these wheels to fit, or could I just swap and go?
  2. TornadoRaptor
    TornadoRaptor FRF Addict
    2,255
    190
    Nov 9, 2016
    NY
    Welcome to frf
  3. Bullishone
    Bullishone FRF Addict
    1,380
    561
    Aug 22, 2011
    You should get the RPG 1.5" collar to avoid any minor rubbing ...
    Sent from my Nexus 6P using Tapatalk
  4. Kowboy17
    Kowboy17 Full Access Member
    174
    89
    Jun 16, 2012
    in an FBI van
    make sure you check the lug nuts and if the stockers will fit into your aftermarket wheels. I just went through this today. Ford changed the thread on the 17's. 14 x 1.5. Most likely you'll need the thin lug nuts since the stockers have a big flair on the end.
Share This Page
