Rigid SS Fogs, XL Hyperspots snd Ignite
Uncas
Heading to Colorado
So I went with Rigid lights in my fog pockets. I used the following:
Diode Dynamics Raptor Fog Bracket
https://www.diodedynamics.com/2017-ford-raptor-led-fog-brackets.html
Rigid D-XL Pro Hyperspots using Upfitter 2 switched with the highbeans using a relay harness from The Retrofit Source.
https://www.rigidindustries.com/d-xl-pro-dually-xl.html
Rigid D-SS Driving using Upfitter 1 when bout as a pair only one side has the side LEDs
https://www.rigidindustries.com/d-ss-series-d-ss-series.html
Rigid SR-M Diffused Driving using Upfitter 3, I burn these all the time, the amber color is very close to the
marker lights. I used a longer SS carriage bolt and double nut to get these to line up with the other lights
https://www.rigidindustries.com/sr-m-series-pro-sr-m-series.html
Great coverage, the D-XL's light pattern is not blocked by the bezel even though they are close.
ewm98
Arizona
Do you happen to have any photos showing how far the hyper spot throws light?
ewm98
Arizona
No worries. I appreciate the pictures and am really impressed with how far the hyperspots project what looks to be useable light. Thanks for sharing.
Uncas
Uncas
Heading to Colorado
There’s a tree in the first photo almost 1/2 mile out that lit up well. The hyperspots will throw light out to about a mile but it’s not of any real use. It reflects off signs at that distance but that’s about it.
gto19
Very nice
Could you post a link to the back lights ?
I’d like to do that
Was it a plug and play kit with the wire harness to go to the uplifer switch ?
Uncas
Uncas
Heading to Colorado
Very nice
I’d like to do that
I didn’t get the harness, instead I ran thru the frame back to Upditter 4. I plan on using them more for trailer hook up and area lighting. But if i need them for backing up, I’ll just flip the switch.
https://www.rigidindustries.com/ignite-backup-kit-bu-ignite.html
I ran the left light wire in 3/8 flex thru the hitch and spliced with the right. It took a little work with a fish tape to pull the flex thru the frame but it’s a clean look. Just need 25 feet of 3/8 flex and 16/18 gauge red and black wire.
gto19
Very nice work
That’s exactly how I would do it .so it looks like the light mounts up using the hole right next to the tow hook . So no drilling it looks like . Correct ?
I will also go to uplifter 4 since 1,2,3 are.
Being used up front with the fog lights
Again thanks!
Uncas
Uncas
Heading to Colorado
Very nice work
Again thanks!
Yes I used the existing holes in the bumper. I had to make one hole in the wheelwell liner for a ziptie. No new holes for the front lights. So far my 18 has only factory holes in the aluminum and no cut wires. Think I might have to drill some in the bed for my recovery box though.
Nick@ApolloOffroad
That's a great setup and I'm happy to see that the Dually XL can be squeezed in there with the D-SS lights.
If anyone would like to go with a similar setup, please reach out and we can help get you setup!
ewm98
Arizona
Did you buy the mount for the SR-Ms or did you fabricate it yourself? I’m having a hard time finding a way to mount mine correctly.
Uncas
Uncas
Heading to Colorado
I used the Diode Dynamics bracket and bought a longer stainless carriage bolt. I put two washers and a nut before the fog light bracket to adjust the height.
ewm98
Arizona
Maybe I’m missing something here but how did that get the Rigid logo on the SR-ms to be facing the correct way. On mine they are upside down. I sincerely apologize if I’m missing something obvious here.
Here’s a picture of what I’m talking about.
Uncas
Uncas
Heading to Colorado
Ok, I got it now, I switched the cover 180 degrees even though Rigid said not too. Two Allen screws in the back allow for removal of the lens. Rotate and reinstall.
101,114
60,284
Selestial
