Rigid pod backup lights install
Chzhead
Wisconsin
TiFJ
Calgary, AB
I think you'll want to run power from the battery and use a relay from the reverse light to power those. You might do better with the diffused pattern as well for a reverse light.
Dane
Littleton, CO
I second both comments here.
You definitely don't want spot, it totally washes out the rear camera and doesn't work well for reverse. I'm personally wrestling with whether I want Rigid flood or diffused (flush mounts) for my rear bumper (I currently have some cheapo floods, but had spots before).
Sernas
You could use a plug in harness that goes to your trailer plug or just tap the reverse light wire at the same plug and ground on the chassis. I would also recommend getting a different light pattern for reverse lights combo pattern at very least but diffused or flood would work best.
Chzhead
Chzhead
Wisconsin
Interesting, I would have thought spot pattern would have worked. Probably not too late to exchange them. I do have a trailer harness spliter that I picked up a few years ago, maybe I can tap into that then.
Thanks guys!
Dane
Littleton, CO
Thanks guys!
Spot is better for reaching out far. For backing up you want more of a broad/close view. Don't learn it for yourself, you'll be annoyed. Rigid has a nice graphic as well as an interactive tool for looking at the beam patterns. Unfortunately their site seems to be down at the moment.
Chzhead
Chzhead
Wisconsin
Yeah, I already reached out to them, see if I can get an exchange. Bought mine on black Friday so it shouldn't be an issue. Glad I reached out before I tried to install them!
Specialtyperformanceparts
Where do you plan on mounting them?
The standard Rigid Brackets won’t fit under the Bumper. I’ve seen people install them hanging down under the hitch receiver? It doesn’t look really clean though. We developed custom brackets to fit directly under the bumper between the tow hooks and exhaust and a custom full length harness to go directly up to the fuse panel. Something you might look at. I put the harness and brackets on EBay stand alone.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/283651527719
Here is a video on install
WY
on my last truck I had a set of rigid floods wired in to the reverse lights. I had a 3 way switch in the cab - on with reverse lights / off / on independent from reverse. I always left the switch in the on with reverse position, then once i had backed up to the trailer I flipped the switch to independent and had tons of light to see what I was doing. This was also great for many other night activities or loading the bed and such. I'd like to do the same on the Raptor (2020 LF Screw hopefully arriving next week). I'm not sure how to accomplish that with the upfitter switches. Any ideas? I was thinking maybe I'd just wire it in permanent for reverse, then wire in an upfitter switch to turn them on indeendently when I want them. Anyone done this?
Also, I had floods. It did wash out the camera some when backing up, but had great light for work. I was thinking I might try diffused this time. Anyone tried both?
Dane
Littleton, CO
My current cheap floods still kinda wash out the rear camera and look spot-ish since it's so close. Mine are flush mount cut into my aftermarket bumper. I think I'm resolved to trying diffused next. I'm looking at the Rigids:
https://www.amazon.com/gp/product/B07N14VJ8B/?tag=fordraptorforum-20
WY
those are exactly what I was looking at. Anyone know if those can be recessed in the stock bumper? I'd check myself but still waiting on my truck.
Those are over MSRP on Amazon! Be careful. Amazon charges 15% fees to sellers, so sometimes we the sellers if we post on Amazon need to inflate prices to even list on there.
Here are the same lights and you can even use discount code Raptorforum100 for 10% off. Free shipping as well.
You can mount them in a Raptor Flush, but they would be slightly Rotated.
https://specialtyperformanceparts.c...lush-mount-light-pairs?variant=25085650174016
here is an old post with pics
https://www.fordraptorforum.com/threads/rigid-radiance-scene-lights-rear-bumper-installed.65024/
Chzhead
Chzhead
Wisconsin
I'll probably end up mounting them similar to my last truck, I attached them to the horizontal pieces of my hitch. However, I have not looked too much into it and gotten under there yet. I had them wired into my hitch plug underneath but want to do a cleaner install. May just wire to an upfitter switch but would like to have them turn on when I go in reverse.
Dane
Littleton, CO
You are posting a different set of lights (exact same price as Amazon). Your link goes to part # 212513
I posted 212513BLK.
Here's the same light on your site - for the same price: https://specialtyperformanceparts.c...series-pro-flush-mount?variant=26531259973696
Your discount code doesn't work for them.
I posted 212513BLK.
We only have a few exclusions, mainly bumpers because there isn’t a 10% margin in them. You can always email us and we can make sure
To apply it or quote you the best price if you see something you want. I’ll look into the code working for them. Again though, feel free to email us any time. If you don’t ask, you don’t know!
[email protected]
101,284
60,415
Gerth
