Rigid Industries :: D-Series :: Dually & D2
Discussion in 'Ford Raptor Lighting Modifications Forum [GEN 1]' started by RigidIndustries, Apr 12, 2015.
Sponsored By: KC HiLiTES
  1. RigidIndustries
    RigidIndustries Supporting Vendor Supporting Vendor
    88
    56
    Aug 15, 2012
    Mesa, Az
    [​IMG]
    We often here these referred to as the gateway light... it's where the obsession with turning night into day begins! :D
    Big Power in a Small Package
    The Rigid Industries D-Series LED Light is one of the most versatile lighting products on the market today. It produces extremely high output while consuming very little power. Its compact size and shape allows it to fit almost anywhere and be used for virtually any lighting application.
    Torture Tested & Approved
    Watch the making of our D-Series after we hit a record number in production, right here in Arizona!
    https://www.youtube.com/watch?v=5hVo7aSIPOo
    Dually or D2? The difference is what's inside:
    The Dually uses our Hybrid Optics System in a 4-LED configuration which comes in either Spot or Flood options. It produces 1,568 lumens at only 15.8 watts and 1.1 amps. To put that in perspective, it uses less power than it takes to use your turn signal.
    The D2 has 6 LED's that utilize our Specter Optics System, which comes in either Driving or Wide configurations. It produces 3,096 lumens and uses only 34.5 watts and 2.5 amps. The D2, with it's driving beam, produces the perfect combination of distance and width for lighting up the road or water in front of you.
    Our new Hyperspot optics are also part of the Specter family and produce 1760 RAW lumens with a peak beam intensity of 93000 cd. The highest intensity per watt or square inch on the market as well as Maximum Distance!
    Why Rigid:
    [​IMG]
    So what are you, or did you start with?
    The Dually or the D2?
    Share the photos of your D-Series with us!
  2. CoronaRaptor
    CoronaRaptor FRF Addict
    11,545
    2,638
    Dec 17, 2012
    Heres my rears!!
  3. The Macf
    The Macf FRF Addict
    6,776
    3,886
    Sep 17, 2012
    Utah
    Do we get a prize for this?
    [​IMG]
    [​IMG]
    RigidIndustries and CoronaRaptor like this.
  4. akmedic77
    akmedic77 Full Access Member
    54
    34
    Sep 29, 2014
    South Central Alaska
    Not a Raptor, but I live in Moose country, so I like light.
    My first gateway Rigid were the Dually Amber Spots. When I had them installed (I install all my own now) I also added the Dually Floods in White. This was prior to the Arc Rite Brush Guard.
    [​IMG]
    JW Speaker Fogs installed.
    [​IMG]
    20" SR2 Hybrid Spot/Driving
    Dually Flood (White) above 20"
    Dually Spot (Amber) in center
    D2 DOT/SAE Fogs in center
  5. Rookie
    Rookie Supporting Vendor Supporting Vendor
    9,766
    3,582
    Dec 16, 2012
    Fort Wayne, IN
    RigidIndustries and akmedic77 like this.
  6. cbcgeneral
    cbcgeneral FRF Addict
    2,489
    1,971
    Nov 26, 2014
    Southeast Pennsylvania
    Hey I wanna play.
    RigidIndustries likes this.
  7. RigidIndustries
    88
    56
    Aug 15, 2012
    Mesa, Az
    Thanks for all the great photos everyone!!!
    We love seeing these in action :happy107:
Share This Page
