Repair/maintenance Manual
Lincoln
What is everyone using for manuals? Looking for something that has torque specs and any other info that will help when I install the supercharger. Just want something that I can look up if I want to take something apart. My biggest worry is swapping out the oil pump gears. Really don't want to screw that up! I see there are CD's, but my laptop doesn't even have a disc drive! Does anyone have a USB drive type? Any direction is appreciated.
Thanks
FordTechOne
Detroit
Are you able to get me a 2017 Ford Raptor service manual?
I can pull individual procedures, but not the entire service manual. It’s a huge database.
Some vendors sell the CDs:
You can also subscribe to Motorcraft Service for access to the all current service publications:
The 72 hour subscription is only $21, that would allow you to save/print off the service procedures you’re looking for.
TwizzleStix
Commivirginia
Yeah, I bought the Service Manual CD through Helm.com along with an external disc drive for my laptop. The wiring diagrams only come in hard copy from Helm. If you’re a DIY owner the few $$$ is worth it having your own copies. If you’re a real details guy like me you can set up your own account with Ford Motorcraft Service for info and Ford Rotunda to buy the IDS/VCI hardware/software!
Gatorgold
Gainesville, FL
I just need torque specs on the front and rear bolts for my leaf springs.
FordTechOne
Detroit
The shackle to spring bolt is 173 lb.ft. The spring to frame bolt is 258 lb.ft. They must be tightened with the weight of the truck on the suspension.
