GEN 1 Removing Fabtech Lift Kit
Raptorlander
Fort Worth
Okay so I’ve gotten tons questions about removing the craptech lift kit that ruins the purpose of a Raptor. .
Disclaimer: This is for informational purposes and is based on my personal experience. Suspension and drivetrain work can be dangerous, so verify all parts, procedures, and torque specifications for your truck. Attempt at your own risk—I’m not responsible for any injury, damage, or other outcome. Know your limits and involve a qualified professional when needed.
Long overdue.
So, here’s a list of items you will need if you’re wanting to return to stock height.
Parts needed to return to stock
  • Front differential assembly — Used, purchased from eBay.
  • Rear crossmember— Motorcraft.
    • Motorcraft mounting hardware.
    • I added washers to compensate for the gap left by the original crossmember mount being cut.
  • Rear alignment buckets, bare steel (pair)— Forge Offroad.
    • These need to be welded into place.
  • Stock-height rear axle blocks (2-inch)— Motorcraft.
    • Not needed if you install Deaver springs.
  • Rear axle U-bolts— Rough Country.
    • Not needed with Deaver springs because the springs include U-bolts.
  • Stock-height spindles— SQHD.
    • I chose the reinforced/gusseted version.
  • Oil-pan skid plate— Forge Offroad.
    • Forge is no longer in business, so Motorcraft is another option.
    • OEM mounting hardware — Motorcraft.
  • Front skid-plate mounting hardware— Motorcraft.
    • The oil-pan skid plate is needed to properly mount the front skid plate.
  • ABS/brake sensor, if damaged— Motorcraft.
    • Not needed if you’re installing new front wheel bearings because the Motorcraft bearings include new sensors.
All the above will get you back to stock. It’s pretty much removal and installation, with the exception of the crossmember mounting area. You’ll need to either fabricate a replacement or purchase aftermarket buckets like I did and have them welded into place. I would not drive without these. Even if you temporarily bolt the buckets on to get to the welding shop, they will at least provide some rigidity.
Getting the front differential back in was a b!t(#... Maybe it was because I was already tired, but having two people would make it a little easier. I used a jack while someone helped raise and lower it as I aligned everything into place.
If you can and want to upgrade the suspension or install OEM replacements, this would be a good time to do it. Otherwise, I replaced parts as they wore out or upgraded them later based on my off-roading needs.
Worn or damaged parts to inspect
  • Front CV boots — EMPI.
  • Front wheel bearings— Motorcraft.
    • Include new ABS/brake sensors.
  • Rear axle overhaul kit — Installed by a shop.
  • Upper control arms — Motorcraft.
  • Lower ball joints — Motorcraft.
  • Front shocks— OEM FOX.
    • The Fabtech kit requires replacing the lower shock bushings with its own hardware. This is a good time to replace or rebuild the shocks, especially if they’re already worn.
  • Rear shocks— OEM FOX.
    • Also worth replacing or rebuilding if worn.
  • Outer tie rods — Motorcraft.
  • Sway-bar end links — MOOG.
  • Rear driveshaft U-joints — Motorcraft
Upgrades added later
These were added later for better off-road performance and a minor suspension lift:
  • Geiser front springs.
  • ICON Dynamics upper control arms.
    • I recently returned to stock UCAs after damaging one of the ICON arms while attempting to replace the Delta Joint.
  • Deaver +4 HD rear leaf springs.
    • Chosen partly because of the added weight from the DECKED system in the bed and I occasionally haul my KTM 500.
  • ICON Dynamics hydraulic bump-stop kit.
    • Later upgraded to 4-inch Locked Off-Road bump stops.
  • 17-inch Method wheels.
    • Once the Fabtech spindles were removed, I no longer needed to run 18-inch wheels.
  • 37-inch BFGoodrich KO2 tires.
I did tons of research before tackling this job, but lessons were still learned, and some parts and hardware I missed had to be purchased later. There’s been other parts I’ve replaced but from being worn or broken (don’t over-torque the CV axle nut).
I may have forgotten a few minor things. This was completed in June 2021, and since then, I’ve taken her to Moab, the Ozarks, Big Bend, Cloudcroft, Baja, Sedona, several off-road parks, and on plenty of long trips. She’s still solid.
Shelter Green
NorCal
What was the reasoning behind the return to a stock configuration? I am interested in why and not looking to start a discussion about the validly of your choice. Cost for the modifications and then a ballpark cost to revert back to stock would also be interesting. Your part list is interesting. Thanks.
Raptorlander
Raptorlander
Fort Worth
Probably should have noted, I bought the truck this way back in 2019 (single owner). Installing a drop bracket lift that requires you to cut both your front differential mounting point and crossmember mounts would never be something I would do for a cheap lift. I reverted it back and then upgraded to a true suspension lift.
As for cost, that was back in 2021 so everything has gone up, company no longer in biz, etc. I was quoted 10k if a shop did it but with upgraded suspension parts like coil overs (that I didn't go with).
Cost of all parts have gone up so it wouldn't be a fair comparison and I saved where I could like the differential from ebay ($650). Roughly it was about 4K to get it to stock which does not include the repairs the cheap lift kit caused. Then tac on all my upgrades after.
Bozz
Royal Smart A$$
Nashville, TN
Probably should have noted, I bought the truck this way back in 2019 (single owner). Installing a drop bracket lift that requires you to cut both your front different mounting point and crossmember mounts would never be something I would do for a cheap lift. I reverted it back and then upgraded to a true suspension lift.
Exactly what I thought.
raptorranger1
They already said it directly in the opening post: it ruins the purpose of the vehicle. It’s a terrible lift system that belongs on your typical 5th owner base F-150 which will MAYBE ever once put its wheel on top of a curb as its max off-roading experience. Its only purpose is aesthetics.
Kaled
I had a Bds lift kit on mine. Thank God that I have the piece that was chopped off from frame ( rear drive side LCA pocket) to be exact. I have welded thag back since 2023 and do occasionaly check on the welds. The truck has a midtravel kit upfront now. Im just worried in the long term this area is a stress area where the LCA might pull on it (the welds)when the suspension is cycling, but its still part of it is supported by the crossmember brace at rear pocket. Here are some pics
Its been painted as well.
Raptorlander
Raptorlander
Fort Worth
If it’s similar to the crabtech bs where it requires to cut both cross member mounts, the LCAs should be fine unless you’re jumping it or something harder.
Kaled
It only required the driver side rear pocket or LCA mount to be chopped off. As you can see from their earlier pics me holding it and matching it up with this screenshot i got. its only this portion that was cut. Also there are 2 mounting bolts that mount or hold this pocket piece to the rear cross member i think. Im thinking of reinforcing it still not sure how or where to start with that just something that would give me some peace of mind. Most of those lift kit companies say this is irreversible and you shouldn't weld it back together..IMG_9552.jpeg
Raptorlander
Raptorlander
Fort Worth
It only required the driver side rear pocket or LCA mount to be chopped off. As you can see from their earlier pics me holding it and matching it up with this screenshot i got. its only this portion that was cut. Also there are 2 mounting bolts that mount or hold this pocket piece to the rear cross member i think. Im thinking of reinforcing it still not sure how or where to start with that just something that would give me some peace of mind. Most of those lift kit companies say this is irreversible and you shouldn't weld it back together..View attachment 537759
I’d get it reinforced, fully welded and that should suffice. Both of mine were cut, and got new buckets fully welded. I have wheeled it all over (no baja blasting stuff) and no issues or concerns.
“Irreversible” bc they ruin these trucks and cause a whole project to return it to stock, it should be banned but to each their own. I would never do such a bs “lift” but I bought it this way (not knowing/lack of knowledge back then).
NMT
This is extremely valuable info. I just purchased a super low mileage Gen 1 with a lot of tasteful upgrades. Unfortunately it has the Fabtech lift. I hate the look and want it level or close to stock. This is quite a nightmare, I would not have purchased a truck knowing I would have to drop close to 5K minimum just to have it back to stock.
Kaled
If you scroll up you will find some pics on what exactly was chopped off on my truck its only the drivers side rear LCA poccket with these bds to my knowldge. Its been 3 years now welded and everything looks normal but OCD always kicks in. Now im planning working with a guy who could reinforce/ triangulate that welded part to strengthen the welds and prevent any deflection due to hard impacts. We may either use 3/16 plates or like a cross tube welded across. Will send pics and info once we figure everything out.
101,289
60,423
HC FabWerks
