GEN 1 Relocate Sub Behind Rear Seats - Rockville Audio 8" Sub
bigrig
San Jose, CA
The Gen1 Raptor's factory Sony subwoofer was a double disappointment for me: I don't think I am alone when I say I felt it stole cargo space and delivered weak bass. Relocating a better sub behind the seats was deemed impossible by professionals. Frustrated, I took a chance on an 8” 400w sub made by Rockville Audio. For just $100, it not only fit but improved the bass response in my music. Most importantly to me, my rear cab is now completely free of that clunky box. It is likely not going to impress any audiophiles or audio installers, but for me it was the upgrade I was looking for. Just thought others may want to know this option is available.
bigrig
bigrig
San Jose, CA
Obvious next question ... how did you wire it? Audio/Power
Power:
I used 8 gauge wire for the power and ground. I ran the power from the positive battery terminal, into the cab through the old FM antenna hole I was no longer using, through the door sills where the rest of the wiring harness is routed, to a fuse block in the rear of the cab (fuse block is not necessary, I just have other lights I want to install in the rear bumper soon so I wanted a convenient place to wire those from). I connected the ground to a common ground in the back of the cab and routed that to the fuse block too. From there I ran the power and ground to the sub.
Audio:
I cut the plug off the OEM sub wires and connected them with 16 gauge wires to the high level input wires on the sub. It took me some trial and error when doing this because the wiring diagrams I found online didn't seem to work. I assume the sub wiring on all Gen1s are the same but I should note that my truck is a 2013. This is what I ended up going with:
BalancePolarityStock Wire ColorSubwoofer Wire Color
L+Purple with Green stripeGray
L-Green with White stripeGray with Black stripe
R+Green with Purple stripeWhite
R-GrayWhite with Black stripe
Here are some more pics below to provide some context. They would likely give a professional audio installer the vapors... you've been warned :)
bigrig
bigrig
San Jose, CA
you will get better sound using the front door woofer input wires.
For me, I just wanted the same or better than what was supplied by the factory and reclaim my backseat. For my non-audiophile ear it seems to fit the bill.
But could share which wires to look for in the front door and how those are different than the OEM sub wires?
The Car Stereo Company
here, on frf
j8j
America
Bigrig:
Thanks for sharing this. I'm new to a Gen 1 and needed the extra floor space in the back. I removed the OEM Sony Subwoofer and loved the space I gained but it did drop the bass. This mod is much better sounding to me than the OEM even with the seats folded up. Thank You.
Shane361
Charleston, SC
I'd grab a grommet for where the wire goes into the old antenna hole. Anything to soften that edge on the power wire. Not sure if the Gen1's have the plastic cap that is under the rear passenger's seat on both sides. Perfect spot run cables through.
