Record setting 2017 Ford Raptor!!!!!
shapiroeric
Longmeadow, MA
That's right folks....I am declaring my Raptor to be a record setting truck....54K miles and a little over 3 years old.....and on oil pan #5!!!!.....that's right, 4 oil leaks....
Brought it in for a coolant leak last week and the also found an oil leak....Ford did give me an extended 75K mile warranty last year for my last issue so it only cost me the $100 deductible....all fixed....
BaseRaptor
SoCal
Wow, lemon law time? Ford didn’t upgrade you to a metal pan to help eliminate the issue?
Raptor911
Ashburn, VA
This has been discussed many times. Ford will not switch to a metal oil pan. You would think it would be easy but apparently it is not. A metal oil pan involves lots of parts beyond the oil pan itself.
MudLovingFJ
Orange, CA
Same thing happened to my 2016 XLT; 5 plastic oil pan replacements. Ford bought it back from me and here I am in a Raptor now.
FordTechOne
Detroit
For all those who are still experiencing repeat oil pan leaks on vehicles with 2 piece (aluminum upper, composite lower) oil pans:
The dealer is performing the sealing procedure incorrectly. Ford developed a very detailed procedure for sealing engine components that require the use of RTV sealant; if the procedure is not followed exactly as outlined, the chance of a repeat leak increases drastically. Each time a composite oil pan develops a leak, a NEW oil pan needs to installed; it cannot be cleaned and re-used. Here is the procedure for reference, its not as simple as scraping off the old silicone and gobbing some new sealant on:
Cleaning
NOTICE: This procedure is only to be used on the sealing surfaces of metal components. Do not use this procedure on non-metal (composite/plastic) components. Failure to follow this direction can lead to malfunction of the RTV seal and fluid leakage.
NOTICE: Place clean, lint-free towels over exposed cavities. Carefully remove the towels so foreign material is not dropped into the cavities. Any foreign material (including any material created while cleaning surfaces) that enters the fluid passages, may cause failure.
NOTICE: Do not use metal scrapers, wire brushes, power sanding or grinding discs, or any abrasive means other than what is specified in this procedure to clean sealing surfaces. These tools cause scratches and gouges which make leak paths.
NOTICE: The order of use of materials to clean surfaces in this procedure is as follows:
    • Motorcraft® Gasket Remover
    • Motorcraft® Metal Brake Parts Cleaner
    • Motorcraft® Engine Shampoo and Degreaser
    • Motorcraft® Metal Surface Prep Wipes
Failure to follow this order will result in failure of the RTV seal and a fluid leak.
NOTICE: The use of latex gloves is recommended. Using latex gloves will minimize the risk of contaminating RTV sealing surfaces and a leak.
NOTE: Bristle discs such as 3M™ Roloc® Bristle Disk grade 120, part number 18733 are acceptable to use for parts that are removed from the engine and vehicle and can be thoroughly washed and cleaned of debris caused by the tool itself and any other debris before installing the part on the engine.
  1. NOTE: This step is to help prevent contamination of an RTV sealing surface from drain down after it has been prepared.
    For oil pan repairs where residual engine oil in the crankcase may drain down and contaminate a prepared sealing surface, spray the interior of the engine block, skirt stiffener and drain back ports with Motorcraft Metal Brake Parts Cleaner to flush away any excess residual oil. Use a lint-free towel to remove the remainder of the bulk oil cleaner from the components.
    Use the General Equipment: Lint-Free Towel
    Material: Motorcraft® Metal Brake Parts Cleaner / PM-4-A, PM-4-B
  1. Remove loose sealant by hand or with the aid of a plastic scraper or plastic razor blade.
    Use the General Equipment: Plastic Scraper
    Use the General Equipment: Plastic Razor Blade
  1. Apply Motorcraft® Silicone Gasket Remover to surface. Allow material to work for several minutes.
    Material: Motorcraft® Silicone Gasket Remover / ZC-30-A
  1. Use a lint-free towel and plastic scraper or plastic razor blade to remove any remaining sealant. Use additional Motorcraft® Silicone Gasket Remover, as required.
  1. For parts that are removed from the engine and vehicle that can be thoroughly cleaned without the risk of contaminating the engine with debris, use a bristle disc such as 3M™ Roloc® Bristle Disk grade 120, part number 18733, or equivalent, to clean the sealing surface.
    Use the General Equipment: Nylon Bristle Disk
    • For oil pan repairs, spray the interior of the engine block, skirt stiffener and drain back ports with Motorcraft Metal Brake Parts Cleaner to flush away any additional residual oil.
    • Use a lint-free towel to remove the remainder of the bulk oil and cleaner from the components.
    • Clean the RTV sealing surface with Motorcraft® Metal Brake Parts Cleaner to remove all residual sealant and oil.
    • Wipe the RTV sealing surface dry with a clean lint-free towel.
    • Inspect and make certain there are no oil contaminants on the sealing surface before proceeding to step 7.
  1. NOTICE: Motorcraft® Engine Shampoo and Degreaser is used to remove residual brake cleaner which can cause RTV failure and prepare the surface for the Motorcraft® Metal Surface Prep Wipes. The use of any other brand engine shampoo or engine cleaner can compromise the sealing surface and could lead to failure of the RTV seal and a fluid leak.
    Use Motorcraft® Engine Shampoo and Degreaser to clean the surface of any remaining oil contamination and prepare the surface for the Motorcraft® Metal Surface Prep Wipes. After Motorcraft® Engine Shampoo and Degreaser, dry the surface with a clean lint-free towel.
    Material: Motorcraft® Engine Shampoo and Degreaser / ZC-20 (ESR-M14P3-A)
  1. NOTICE: Motorcraft® Metal Surface Prep Wipes can only be applied to a dry surface. Failure to dry the sealing surface before using Motorcraft® Metal Surface Prep Wipes can result in a failure of the RTV seal and a fluid leak.
    NOTE: Motorcraft® Metal Surface Prep Wipes is a pre-saturated, wet disposable wipe to be used as a final step in surface preparation. The wipe fluid creates a conversion coating providing an improved base for RTV sealing. The fluid should be allowed to dry in place. It does not require rinsing.
    NOTE: Discard wipe after a single use.
    Prep the surface with Motorcraft® Metal Surface Prep Wipes. All metal surfaces to be sealed with RTV are to be wiped. Make sure the entire surface is moistened with the fluid.
    Material: Motorcraft® Metal Surface Prep Wipes / ZC-31-B
  1. NOTICE: Drying the surface with a towel will contaminate the surface and may cause oil leaks.
    NOTICE: If the metal sealing surface or an area of the metal sealing surface becomes contaminated after it has been prepared, or if fluid from the Metal Surface Prep Wipe beads up on the sealing surface, use a lint-free towel soaked in isopropyl alcohol to clean the area. Prepare the area again using Motorcraft® Metal Surface Prep Wipes.
    Allow the fluid applied to the metal sealing surface to air dry. (Approximately 2 minutes.)
    Use the General Equipment: Isopropyl Alcohol – 90 Percent Minimum
Moridin
N. Cal
Cleaning
Service Guy: "TL;DR."
richnot
Central New Jersey
I think that you should let the Service Managers on to that. Only kidding, it's like you're better off doing it yourself because if you question the Service Manager about it you get the Stink Eye.
Like everything else it all depends on who's doing the work and if they give a hoot about it.
Warranty work scares me, I had my vehicles come back with more damage/issues/problems then when I dropped them off.
Not just at a ford dealer. Jeep and BMW too
