Recommendations on Modest Mods
Discussion in 'Ford Raptor Engine Discussion and Performance Mods' started by mrwizard93, Apr 9, 2012.
Sponsored By: GotExhaust
  1. mrwizard93
    mrwizard93 Member
    14
    Apr 9, 2012
    Miami, Florida
    I just got my 2012 Raptor less than a week ago and was wondering if there is a section on recommended mods.
    I am looking at modest mods - nothing like putting in a SC or anything like that.
    In my old F150, I put in some nice dual exhaust pipes out the back and had a K&N filter kit installed. I did notice a little something with regards to performance when they went it - although nothing to write home about.
    I don't want anything that will blow the bank or kill my warranty. But it would be nice to heel a little extra kick when i push on the petal.
    Any suggestions??
    Also, are there any reputable mod places in the Miami, Florida area that anyone uses?
    Thanks to all!
  2. Humvee21
    Humvee21 FRF Addict
    26
    4,839
    526
    Aug 17, 2011
    Most here have the 5 star tune with AFE intake (also from 5 star).
    Also, magnaflow, stainless works, borla, roush, and corsa (maybe more) have received mostly positive reviews.
    Be wary when installing a tune... some say it will void warranty. However, this is easily avoided by reverting back to stock tune when you take it to the dealer. As you may already know, full warranty cannot be voided unless the root of the problem you may have is from the aftermarket mods.
    Good luck
  3. mrwizard93
    mrwizard93 Member
    14
    Apr 9, 2012
    Miami, Florida
  4. Deinonychus
    Deinonychus FRF Addict
    1,089
    244
    Aug 1, 2011
    Jacksonville, FL
    A small physical fact: the lower the pressure drop across the filter the more available air to the motor.
    That said, it has been my observation, most aftermarket CAI's have similar filter cross-sectional areas. The difference in filter material will also affect pressure drop across the filter.
    Care should be taken to chose a filter that will protect the motor from foreign particles, even the smaller ones. Care should also be taken to avoid water intrusion, i.e., a slug of water.
    Others will also comment some other concerns.
    IMO, there is very little, if any, performance difference between the Airraid and the AFE.
    Big Blue likes this.
  5. mrwizard93
    mrwizard93 Member
    14
    Apr 9, 2012
    Miami, Florida
    It looks like I will be hitting up the X3 Stage 2 with the programmer ... By the picture, it looks like the install is pretty easy.
Share This Page
