Recall Alert: Interior Door Handle Latch Fault
pirate air
will plunder your booty
VEHICLE MAKE/MODEL: MODEL YEAR(S):
Ford/F-150 2009-2010
MANUFACTURER: Ford Motor Company
MFR'S REPORT DATE: January 28, 2011
NHTSA CAMPAIGN ID NUMBER: 11V049000
NHTSA ACTION NUMBER: N/A
COMPONENT: Structure: Body: Door
POTENTIAL NUMBER OF UNITS AFFECTED: 280,946
SUMMARY:
Ford is recalling certain model year 2009 and 2010 F-150 vehicles manufactured from January 18, 2008, through November 30, 2009. The interior door handle housing embossment retaining the interior door handle spring may fracture during normal usage resulting in insufficient spring force to return the handle to the fully stowed position.
CONSEQUENCE:
In the event of a side impact crash, the door handle spring can fail causing the door latch to open.
REMEDY:
Owners will be initially notified and instructed to take their vehicles to a Ford or Lincoln/Mercury dealer if any interior door handle is loose or fails to return to the stowed position after activation for replacement of the affected module. Once parts become available, owners will be renotified and instructed to take their vehicles to a Ford or Lincoln/Mercury dealer for inspection of each interior door handle. Depending on the results of the inspection, the dealer will either add a spring embossment reinforcement or replace the interior door handle module free of charge. The safety recall is expected to begin on or about February 14, 2011. Owners may contact Ford at 1-866-436-7332.
NOTES:
Ford's recall campaign number is 11S15. Owners may also contact The National Highway Traffic Safety Administration's Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to Home | Safercar -- National Highway Traffic Safety Administration (NHTSA).
2011 Raptor with same probem as 2009/2010 recall - FORD HAS BEEN NO HELP
I have a 2011 with the same problem as above. The drivers side door handle does not return to closed. This has caused the door to fail to latch when being closed on multiple occasions, and has caused the "door ajar" warning indication to trigger when riding down the roadway. On at least one occasion the door has opened while being driven due to the latch not engaging. Please review and consider having the NHTSA action expanded to the 2011 year model F-150. Problem has been ongoing for several months. Vehicle was brought to the dealership and I was notified that this item was NOT covered under the premium warranty and that Ford was unaware of this problem on the 2011 model F-150.
I have reported this problem to the NHTSA website.
