Rear OEM camera Install/programming
DieselD
Arizona
So my 2011 has the Nav system yet is missing the rear camera. I have been on the fence to do the install as its one of those luxury items that you ask yourself do I "really" need that? I do find myself hating backing up with the huge blind spot the F150 has. I did remove my rear headrests to aid in seeing behind me but having a back up cam will be even better. Having the ability to do the programming myself and getting a good price on the parts helped sway me in the direction of doing the retrofit.
I will get a part number list up for you guys looking to do the same. It is pretty straight forward with the camera itself being the expensive part. Also keep in mind you will probably need to pay for programming at the dealer unless you happen to have access to IDS. I will also explain in a little detail on the programming when I get to that point. It might help those of you with dealer that says its not possible.
Part #s required
BL3Z-19G490-B Camera Assembly
N895949 Screw (2x needed)
W714711 Insert (2x needed)
AL3Z-19H511-A Camera housing
BL3Z-14A411-A Wiring Assembly
CL3Z-9942528-AA Name Plate Ford Emblem
Mount the camera assembly in the new emblem housing, it only fits one way so no worries on having a misadjusted camera alignment
Use a heat gun to heat up the original ford emblem to remove the gate and clean up all the left over 3m tape. Feed the wire harness down the tailgate through the center opening in the bottom of the gate
Here is the factory location of the camera plug. There will be a blank installed you will need to remove
Thats it for the parts install, it was very easy and maybe took me about a hour only because removing the old emblem was a bit time consuming.
The next step in the install is programming of the Audio Control Module or ACM for short. The rear camera information is passed through a couple modules including the FDIM and BCM. The ACM however is going to be what you want to change to get the camera to display on your Nav screen. Your going to need the As-Built Data from a vehicle that was built from the factory with the options your trying to install. In this case I needed a VIN from a Raptor that was built with a Backup Camera. Its always best to find a truck as close to yours as possible for example mine is a 2011 so I wanted to find another 2011. I just so happened to find a VIN for truck on ebay with a build date 1 month newer then mine but getting within the same model year is enough. From there is was a matter of running the VIN for the AS-Built Data for that vehicle. (If anyone needs help with getting as-built data let me know). The ACM data is 18 lines of code which basically tells the ACM what to look for on the vehicle for installed equipment such as the back up camera. After entering all the data into the programming section of the IDS you can upload it to the module and enjoy the features of the backup camera.
A interesting feature I missed with the excitement of being able to see behind me is your able to zoom the camera to aid in hooking up a trailer. I have the button on the screen to select however it does not zoom when pressed. I believe this feature to be controlled through a different module either the BCM or FDIM and I will need to change the AS-built for that module as well. Im not to concerned with it at this point in time as everything else functions as it should and when I get some free time I will investigate further.
KNUCKLEBUSTER
OHIO
back up cam
You need to ck and see if the truck has correct main rear harness and I can bet you are gonna need more than a camera and tailgate harness. I added a rear camera to a 2011 fx4 quite a job, call tasca ford they can help you with part numbers and everything you need.
DieselD
Arizona
I have already checked the truck and the plug is already there and ready to go. I have a few more things like bolts and clips that are not pictured. Really its just the camera, ford emblem housing and emblem, and tailgate wiring.
Thanks for the lead on advice but I have the access to anything ford wise I need.
DieselD
Arizona
Testing my programming before I install the camera in the tailgate. Simply plugged into the harness on the truck that was already there and made some changes to the ACM AS-built data and viola it works....
DieselD
Arizona
Updated the first post with pictures and a little explanation of the programming involved.
If anyone needs help with this let me know. I can offer programming to anyone local to AZ
Lpasteur
4.2"screen programming
I want to know what as build data do I need to change? I want to do this with my 2012 explorer. How do I change the as build data??
Barleypop
NC
I have this Exact truck, 2011 with Nav, I followed the instructions and installed everything. I have Forscan, and know how to use it. But for the life of me I can not find the ACM data I need to input for the camera to show up on the nav.
Members online
93,145
56,419
TwistAir
Latest posts
