Rear end noise
  • Start date
Guest
Is this normal?
Also anyone know what the rear axle in-play tolerance specs are?
xtela
Sounds like the wheel bearings are noisy.
From the 2014 service manual. 9.75 rear end.
General Specifications
Item Specification
Available drive pinion shims in steps of 0.25 mm (0.010 in) 0.254 mm (0.010 in) —
0.965 mm (0.038 in)
Electronic Locking Differential (ELD) side gear backlash 0.100-1.000 mm (0.004-0.040 in)
Maximum differential case flange ring gear runout 0.076 mm (0.003 in)
Maximum variation between ring gear teeth 0.102 mm (0.004 in)
Pinion bearing preload 1.8-3.3 Nm (16-29 lb-in)
Ring gear backlash 0.203-0.304 mm (0.008-0.012 in)
Maximum axle shaft flange runout 0.279 mm (0.011 in)
AZEngineer
Phoenix AZ Area
I have not played with my truck so I have no direct advice. It does sound like a rear end sounds like when adjusting the shims when there is no gear oil. I would not say normal.
Guest
Emailed the video to the dealership. Said bring it in and they think they either need to replace the axles, bearings or rear end. Nice....
Guest
Rick, whatever came out of this? I think I might be having similar issues.
Dealership replaced the axle bearing and noise no more. That was not normal. Will have to look up the work order and see what part it was and can post back.
AndysLog
Moro IL
it sounded like the axle bearing right on the edge of the axle housing to me.
i havent gotten into the internals of these axles yet but the bearing/cup/seal wouldnt cost more than 60-80$?
