Rear camera defaults to split screen
Raptorguy1
I've owned quite a few Fords with backup camera and always have been able to have the entire screen show the rear view with guidance lines etc. On the Raptor, it keeps defaulting to a split screen with half showing the rear and the other half an above view. In order to get full rear view, I have to reach over and press the settings button every time I back up. The part I don't like is the trans is in reverse while I'm fooling around with the setting. Is there a way to set it to stay on full rear view?
sdorn
Georgia
I find that irritating as well. If there is a way to change it I am interested in hearing it.
vitaminR
Winchester, VA
The split screen is even more awesome when its broken.
I had my camera replaced by the dealer a few months ago on my 18. Since then the rear panel of the 360 is just black. They can't figure out how to code it. I just give up and use my mirrors anyway. I'm too old to adjust my backup procedure and can't seem to trust the camera.
R
Raptorguy1
If you hit the camera button on the dash next to the hazards you can change the picture view
That's what I'm doing. I'm not used to it yet, so I start backing up and realize I need to change it. I'm afraid I'm going to end up hitting something or someone messing around with this. I've never had one that you can't set the full view and it will always stay that way.
bo1966
You spent how much on your truck and won't force the camera issue???? It's the same system in all Fords with the camera. You can't tell me every Ford that gets wrecked, people give up this option when it gets out of the shop
lightman02
New Jersey
Mine doesn't split screen by default, it's either in the guage cluster or most likely sync settings on the second screen under "display". You shouldn't have to hit the button every time.
SENDIT
The "+" in the upper, left hand corner of the screen changes the view from split screen to full screen
R
Raptorguy1
Yes, you have to select it each time you want full rear screen. If I was in a situation where I needed to back up several times, I'd need to keep hitting that button each time I put it in reverse. I've owned a lot of Fords and this is the first one that I can't get the default to full rear screen.
lightman02
New Jersey
The you can try doing a "Master Reset" on the Sync system to wipe out everything and see if that will solve your issue. Otherwise I would take it to your dealer because it should save the setting.
R
Raptorguy1
My salesman tried getting it to stay in full rear display, but he couldn't get it to work either. I'll swing by the service dept and see what they think.
lightman02
New Jersey
I'm sorry I'm a moron, I was thinking you were talking about a split in the middle of the screen such as upper and lower half. If you are referring the split on the right side, yes mine has that as well. However I noticed if you change it to full screen mode you don't get anymore field of view as it just stretched the image it seems. I never noticed it as I have gotten so used to it, sorry for the confusion.
R
Raptorguy1
I did go to the dealer and apparently, that's the way it is with the new 360 camera. The service writer spent quite a bit of time researching and I could see he even looked on Forscan to see if there was anything. I guess someone thought having 2 views crammed onto such a small screen a good idea and if you want to change it, do so with the vehicle in reverse while doing so.
101,103
60,269
forddar
