Rear Bypass and Dual Valve Delete Advice
Shaheen J
Earth
Well....I thought I was done with my build but apparently was wrong. I need some help with the live valve delete.
I am currently running the Foutz Mid Travel with that utilizes the factory dual live valve in the front and add Fox Bypasses.
In the back I am running Foutz Billiet 5 link with Eibach 1.2" springs with the factory Dual Live Valve.
The rear is not keeping up with the front so I want to go with a rear bypass rack.
Here is the current plan for the rear:
1. SVC rear bypass Rack V2
2. Fox 3.5x18" Bypasses replace the rear dual live valve.
3. Change out the rear 1.2" Eibachs for Icon 1" overlands because they have 2 more inches of droop and can better utilize the 18" vs 16" fox bypasses.
Seems straight forward until I get to the Dual Live Valve delete.
Has anyone successfully deleted just the rear and kept the front fully functioning? If not, I need to delete the front and go with Icon 2.5 springs all around and replace the front shocks with Fox Factory Race too.
So my question is does anyone have have experience with a partial dual live valve delete or a complete dual live valve delete. Not a fan of running around with my check engine light on and numerous alarms going off at every startup. Appreciate the help.
RoNiN Raptor
Army Supporting Member
Arizona
I’m one step ahead of you currently…
Front SVC mid-travel with Kings. I swapped the rear out for SVC and King 3.0’s and it didn’t keep up nearly as much as I was hoping.
The end of October my truck goes back into TSW to get SVC bypass and King 4.0’s put on with some other goodies.
To answer your question I’m not sure you can partially delete the live valve, it’s either all or nothing from what I’ve researched and asked about.
I would recommend deleting the live valve and just letting your upgraded shocks / springs handle the work. I haven’t missed the suspension modes what so ever. With the delete you don’t get any type of warning lights or alerts.
S
Shaheen J
Earth
Thanks for the Reply. Sounds like your build is coming along like mine. Try this, try that and see what sticks :). I definitely don’t need drive modes. Was your live valve delete single live valve or dual live valve from the factory? If dual, what did you use?
RoNiN Raptor
Arizona
Yeah I honestly thought the rear would keep up better but after two hard runs it just wants keep swinging around. The SVC bumps I put on have helped to keep from bottoming out.
I was single live valve and just removed everything and went with Kings.
Nick@ApolloOffroad
I've not done it yet on a dual valve truck, but on @Johnny@ApolloOffroad's truck, he has the front live valve shocks functional with E-CLIK and the rear with the RPG setup is disconnected. Front w/ E-CLIK still works. I'll let him touch on it more.
downforce137
In Diana
you can take the coils off the shocks, and install a bolt thru the middle, and the system will work normally.
def the cheapest way out of live valves.. mine have been zip tied under the rear frame for a few years now on my Gen2 with no issue.
i recently bought some king coilovers for the front so i got the off road research live valve delete box for the VDM to get rid of all of it.
S
Shaheen J
Earth
I don’t think the gen 3.5 works the same way the gen 2 and gen 3 shocks work. At least not the 3.5 dual valves.
downforce137
In Diana
Looks like you're right.. I just looked at the pics and it appears the connector is directly to the shock.. sorry to hear that.
I have a buddy with a full SVC build Gen3, and he's got this..
Says it works with dual live valves, but you'd have to call them to retain the front im guessing
looks like theres other options than EClik
S
Shaheen J
Earth
Nice find…thank you. I’m going to talk to them tomorrow and see if this will get’er done. Will report back.
TX
My rear shocks are actually still live valve, however I believe we can only do this with a coilover and not the rear bypass set up.
OP, call the shop and ask for me, id be glad to talk it over.
101,329
60,419
clong18
