Rear Bumper assistance needed
Discussion in 'Ford Raptor Maintenance Forum' started by Will_Lyon9, Jun 14, 2016.
  1. Will_Lyon9
    Will_Lyon9 Member
    7
    May 24, 2016
    Flower Mound, TX
    I reversed into a metal bollard in a car park (the truck won) and needless to say the pole was clean ripped out the floor.
    However i do now have a dent in the rear passenger side bumper. I know these come in two parts (one for each side).
    Does any one know where i can procure one from? I should probably replace the plastic guard that goes over the top but the main fix is the metal grey bumper.
    Thanks!
    Will
  2. sandtrooper29
    sandtrooper29 FRF Supporting Member Supporting Member
    389
    155
    Dec 22, 2013
    Lubbock, TX
    Where are you located? I have a few at the shop
    Will_Lyon9 likes this.
  3. Will_Lyon9
    Will_Lyon9 Member
    7
    May 24, 2016
    Flower Mound, TX
    i'm based in Plano, Texas.
  4. R1jamn
    R1jamn Full Access Member
    54
    394
    280
    Jun 18, 2011
    Be careful when removing the plastic cover from the metal section that you are replacing.
    The plastic cover has built in clips (molded right onto the plastic) that then snap into the metal portion of the bumper.
    For removal, the clips need to be compressed and this can be fussy as these clips can break off.
    The clips have very little room for compression which makes the process a bit burdensome.
    Some body shops will typically break the clips off and throw out the plastic cover and then install a whole new one.
    beemerman likes this.
Share This Page
