Rattle above passenger seat
SD1290
Seattle
New 2018 with 650 miles, rattle above passenger seat. I assume this is the the dual pane moonroof? Anyone else that experienced this have good luck with the dealer remedied solution?
Thanks
1roadking
Mine was doing it, I opened it to the vent up position cleaned it off and reckoned it and it’s gone. I’m sssuming it needed to adjust and reseal in the cold weather.
S
SD1290
Seattle
Thanks for the response, I tried venting a few times and it didnt work, what did you mean by reckoned it?
It’s definitely been colder here lately
GCATX
King Dingaling
Central Texas
My rear roof glass panel was rubbing/rattling against the rubber gasket. Sprayed some silicone spray around the outside perimeter, wiped off with a towel. Instant quiet.
S
SD1290
Seattle
Ok I’ll try that, thanks!
mamula
***** Den
Now I see why many folks don't want the moon roof. I think I might lean towards not getting it. Will lead to some foreseen problem along the way.
1roadking
Typo, I meant re-closed it lol. I just ran my hand down the two surfaces while it was open and that was enough to let it seal tight. My thinking is the cold shrinks the panel ever so slightly and it lets dust in between the gaskets. Once cleaned it re-aligns and is good to go.
S
SD1290
Seattle
Thanks! I will try this.
S
SD1290
Seattle
You won’t get one on your non-existent Raptor?
I love the dual pane, makes the truck feel roomier, wouldn’t own a raptor without it
squeak
I noticed mine just recently did this too and it also recently got really cold. I tried venting it and it didn't change. While out this morning I slid it back a little to open it and then closed it and it's gone. Rattle completely gone.
Sent from my SM-G950U using Tapatalk
