Raptor Power Steering Pressures
RaptorBri
Edmonton, Alberta
Maybe the admins can post this information as a sticky as it seems very difficult to find this information.
With some of the Raptor Power Steering upgrades being launched, a number of my customers were wanting to know the stock pressure of the PS pump.
3 gal/min flow @145 psi at 1500 rpm, 1.6 gal/min flow @ 725 psi at 500 rpm. Relief bypass pressure in the pump is set between 1400 - 1520 psi.
RaptorBri
RaptorBri
Edmonton, Alberta
PS Rack Bolt Torque
When Replacing or removing the PS Rack bolts for the Raptor, Ford recommends replacing the bolts with new ones.
Bolt Part # W713954
Torque Bolts to 325 lbft.
gtxracer
Do you have any data for 5000rpm? Max GPM? Max Pressure? I see Lee has a TC pump replacement but a CB pump would flow much better at idle for parking lots and especially in sand/gravel where the traction is high. I went from a TC to CB in my Jeep and it was a huge difference. FWIW the TC pump was from PSC and the CB from Lee.
