- Joined
- Jan 29, 2012
- Posts
- 1,270
- Reaction score
- 635
For Ranger Raptor owners who want the most light behind the grille, this is our dual light bar kit: a 40" SLIM bar on top and a 30" SLIM bar below.
Fitment
Install
Light output
Every SLIM bar uses a Spot & Flood pattern, blending a focused spot beam with wide flood coverage for a balance between distance and width.
You choose a color for each bar separately, the 40in top bar and the 30in bottom bar can be different.
White: 40in bar: up to 15,000 lumens • 30in bar: up to 11,760 lumens
Bright, powerful light for any adventure.
Amber: 40in bar: up to 7,000 lumens • 30in bar: up to 5,500 lumens
Cuts through dust, fog, snow, and rain far better than white light. Ideal for poor conditions.
Dual Function: White + Amber DRL: Full white beam (same as the white option), plus an amber daytime running light backglow. Doesn't give off much light, just a bold amber glow that makes your vehicle stand out on the road.
Build quality
Questions about fitment on your truck? Ask here and we'll help.
Forum members get 10% off with code FordRaptorForum at checkout.
2024+ Ford Ranger Raptor Dual Light Bars
Fitment
- Fits 2024–2026 Ford Ranger Raptor
Install
- You receive one 30in LED light bar and one 40in LED light bar
- 30in is below, 40in is above (you CAN NOT) interchange them
- Doesn't interfere with active grille shutters
- Metal bracket is powder coated black
- The light bars cover only a small portion of the total grille opening, leaving the surrounding mesh open for full radiator airflow and factory cooling performance
- No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware
Light output
Build quality
- Reflector-style optics with CREE XT-E LED chips for consistent, efficient output
- Housing is UV black powder coated to protect against fading, corrosion, and weather exposure
- Rated for a 50,000 hour lifespan
