Radio shop in MI or OH?
Discussion in 'Midwest' started by RaptorActual, Oct 10, 2017.
  1. RaptorActual
    RaptorActual Full Access Member
    67
    8
    Aug 5, 2016
    Sunrise, Fl
    Hey guys looking to have a vhf radio installed in my raptor want to do the the external face in the roof panel in front of the sunglasses holder. Does anyone know of a shop that sells/ installs them in lower Michigan or Ohio?
    Kmandoske likes this.
  2. McGrath4u
    McGrath4u Full Access Member
    302
    223
    Dec 23, 2014
    @Kmandoske should be able to help. He is in Illinois but you may be able to work something out with him.
    t_j likes this.
  3. McGrath4u
    302
    223
    Dec 23, 2014
  4. RaptorActual
    67
    8
    Aug 5, 2016
    Sunrise, Fl
    Thanks for the reply
  5. Kmandoske
    Kmandoske Full Access Member
    235
    319
    Oct 5, 2012
    Bartlett, IL
    did you figure something out? I might be able to help if your still looking
  6. RaptorActual
    67
    8
    Aug 5, 2016
    Sunrise, Fl
    No I haven't I have a idea of how I want it set up
  7. downforce137
    downforce137 Full Access Member
    682
    351
    Jan 5, 2016
    In Diana
    i put my TYT9800 face plate up there..the only bad part is the screen is bit hard to read. i put the the radio under the passenger's seat and put an external speaker on top of the dash. really wasn't bad doing it myself, and i drilled the roof for an NMO mount. eventually, ill route the mic cord down by the console..right now the cord is coming out by the sunroof and i use a magnetic phone holder glued to the passenger visor..
    ill get some pics for you.
  8. RaptorActual
    67
    8
    Aug 5, 2016
    Sunrise, Fl
    What radio did you go with and how does the face plate mount?
  9. downforce137
    682
    351
    Jan 5, 2016
    In Diana
    TYT TH-9800.
    It comes with some mounting hardware, but I think we used a piece of angle iron screwed into the plastic support behind the headliner.
  10. McGrath4u
    302
    223
    Dec 23, 2014
    I have a similar one from LVJ. Comes with a faceplate and switches if you want more auxiliary lights. Keith includes a template. You simply cut the headliner and screw the mounting plate to the hard headliner plastic. Run the phone cord to the base unit. Base unit to the battery and to your antenna. Holds up to great abuse.
    downforce137 likes this.
Share This Page
