Question on dually lights
Discussion in 'Rigid Industries LED Lighting' started by mudblood, Feb 22, 2014.
  1. mudblood
    mudblood FRF Addict
    72
    1,429
    609
    Nov 11, 2013
    Atlanta
    I purchased the Raptor set up with brace and twin duallys on each side. Perfect for driving and fog with ambers. Have had about two months when I noticed the dreaded condensation on the glass of one dually. Have tried running the light to heat up area and evaporate condensation with no luck. I really don't want to have to remove the light and return as it would be a Huge pain but I am hoping there is anther way to remove condensation. Any suggestion from Rigid or any of you experts?
  2. justvettn
    justvettn FRF Addict
    4,359
    916
    Feb 9, 2012
    GTA
    Rigid will exchange it as you know, but if you want to fix it yourself, you could take the front cover and glass off. Clean it and add some silicone on the rubber gasket to give it a better seal.
    P.S. do this at your own risk, Rigid may void your warranty if you tamper with the light.
  3. mudblood
    mudblood FRF Addict
    72
    1,429
    609
    Nov 11, 2013
    Atlanta
    That is what I am concerned with. I guess it will not go away with hot weather. Really a pain in the ass to have to remove it. I guess Rigid has no comment.
  4. justvettn
    4,359
    916
    Feb 9, 2012
    GTA
    They have a vent in the back so it should dry up with better weather, also if you drive with the light on for an extended period that should help as well.
  5. mudblood
    mudblood FRF Addict
    72
    1,429
    609
    Nov 11, 2013
    Atlanta
    Thanks vetting. That is what I am hoping. The condensation is not bad but not sure how it will shorten life. Only one light out of four. Sure wish Rigid would step up to the plate and comment. I am like many others a good customer and would like to hear their comments and suggestions.
  6. justvettn
    4,359
    916
    Feb 9, 2012
    GTA
    Send them a PM, I don't think they have been on the forum lately.
  7. nsdq3
    nsdq3 Full Access Member
    46
    447
    104
    May 27, 2012
    West Point, VA
    You can drop a light without taking the bracket off
  8. iSurvive
    iSurvive FRF Addict
    1,272
    773
    Feb 26, 2012
    Highlands Ranch, CO
    They will take care of your moisture problems by doing a warranty replacement. I've only had one issue and Rigid made it right.
  9. mudblood
    mudblood FRF Addict
    72
    1,429
    609
    Nov 11, 2013
    Atlanta
    Yes I understand they are very supportive of their customers. I was just hoping I could do something to help remove the condensation without removing the light and having to ship it back. Just looking for a more simply option. Guess I will communicate with them directly. Thanks everyone for your comments. I would like to say I am very pleased with their products. I have plenty of money sunk into all their lights with out any issues other than one light with minor condensation.
  10. Rookie
    Rookie Supporting Vendor Supporting Vendor
    9,767
    3,590
    Dec 16, 2012
    Fort Wayne, IN
    I'd remove the front face, very easily done with some Allen wrenches, then use a heat gun or blow dryer and carefully use it to remove the moisture. Replace the front plate and use some silicone to seal it up. I did this before I put them on to help mitigate the issue from the start.
Share This Page
