I have 5% window tint on my truck, I am looking at doing a corner fog light and a flood light that would be appropriate to run while driving on the street. Then I will run the 3rd set as the brightest available for off road, any thoughts on what I should use?
I'd recommend our SPP Triple Fog Light Kit, which is here:
http://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-baja-designs-lights/
I personally run the S2 Pros in Wide Cornering as my main light, always on. Then a pair of Squadron Pro Driving/Combo followed by a pair of Squadron Pro Wide Cornering Amber.
I'd recommend going with the 3rd pair as Squadron Pro Spots. That is the most popular combo.
The S2 Pros in Wide Cornering are awesome for everyday use (or every-night use). However you could also put in the SAE Lights as pair #1 which gives you that street legal output. So a really cool option (which is what i'll be doing on my own) is the following:
Squadron SAE Wide Cornering
Squadron SAE Wide Cornering Amber
This way you can pick/choose between an amber or white light for use on the road.
OR if you only ever plan on running the white lights
Squadron Pro Spot
That would be a killer combo.
You have a lot of choices. Our SPP Kits let you pick/choose which lights you go with. We include a custom-made all-in-one wiring harness along with the stainless steel american made brackets.
We have everything in stock as well, including the new SAE lights in both white and amber.
