Question on a 3" lift for a 2000 F-250
Tituslloydpullo
I'm just double checking that I've got all the parts I need coming to me.
2000 F-250 4x4 7.3 extended cab.
1 ICON-33099 3' LIFT SPRING HANGER KIT
1 ICON-33100 FRONT 1' BUMP STOP SPACER
1 ICON-194275 4" FABRICATED REAR BLOCK
1 ICON-37003 REAR U BOLT KIT (SPRING W/ FACTORY BLOCK) 15"
2 ICON-36507 99-04 2.0" FRONT 3-6" SHOCK
2 ICON-36508 SD 2.0" REAR 3-6" SHOCK
Is this a complete list of parts I need for the install?
Extended Brake lines?
Steering Stabilizer unnecessary?
Any suggestions?
Thanks.
---------- Post added at 06:48 PM ---------- Previous post was at 06:38 PM ----------
I forgot to mention its a flat bed. Seems level now. Rides great.
Pics here, I keep getting errors when I try to upload newer pics. ARGH.
http://www.fordraptorforum.com/f89/my-bro-giving-me-7-3-f-250-what-should-i-do-18361/#post302969
Conejoracer
Conejo Valley, California
Looks complete except for a track bar drop bracket. I'd recommend buying an adjustable track bar from icon instead of the drop bracket.
I did not need extended brake lines or a steering stabilizer on mine.
I had the same kit on my 02 F250, but I ran dual bilsteins on the front.
Back then Icon was called Donahoe Racing Enterprises.
ICONRep
Riverside, CA
Any suggestions?
Thanks.
That is def a complete kit......and a track bar is not required how ever if it was mine I do think it is a quality part I would want on my truck. Not only for strength but to keep the front end adjusted properly under the truck. No brake lines or stabilizer is required but I do again like the stabilizer option
Keep in mind installing a 4" block will sit the back a smidge high (less the factory rake) in the back.......just wanted you to know that.
T
Tituslloydpullo
Thanks for the response. I'll get the parts I listed on, then Ill plan on doing the track bar and stabilizer later.
The truck could use a little height in the back. I cant upload pics for some reason.
T
Tituslloydpullo
Just saying thanks alot for the advice. I got the track bar on. Definitely the right thing to mechanically do.
I still havent changed tires and wheels. Maybe ill need the stabilizer after.
ICONRep
Riverside, CA
