Question: Gen 1 - 6.2L Engine Failure at 252K miles
ERICB100
Florida
I had previously posted here about my Gen 1 Screw 6.2L valve spring break and repair. After the repair, the truck ran great and I used it as my daily driver for more than a month. I work from home so daily driver equated to ~222 miles of short trips. I have since sold the truck. The guy who bought it thoroughly inspected it and seemed to know what he was doing. He climbed all over it and under it with the engine running and we took it on an aprox. 13 mile test drive that included lots of stop/start driving and some highway driving at higher speeds. He was satisfied and bought the truck. I full disclosed the truck's history including the valve spring repair and even gave him a link to my posts on here which he read. He lives about 3.5 hours from me and unfortunately the truck did not make it to his house.
So a quick timeline/mileage:
  • The truck belonged to my GF's son and it went down with the broken valve spring in mid-February at 251,606 miles.
  • I got the truck on April 10th and replaced the valve spring on April 12th. The mileage was unchanged during that time because it didn't run and it was moved around on a flatbed.
  • After i got it running, the truck went straight to the transmission shop and I picked it up on April 28th. I maybe tinkered with it another week or so before I started driving it daily.
  • I drove the truck as my daily driver from early May until June 4th (minus a 9 day vacation). I put 222-ish miles on the truck.
  • I sold the truck on June 4th. I made a bill of sale the day before he came to get it and the truck had 251,838 miles (so ~222 miles since the repair).
  • After that, I took it to put gas in it before he arrived and then we took it on the 13-ish mile test drive so maybe another 14 miles were on the odometer (getting close to 240 miles since repair).
  • After he bought the truck, he was driving it home and got around 150-160 miles into his trip before something failed.
  • At this point, I assume that the truck has driven around 400 miles since the valve spring had been replaced.
The failure:
He texted me that "something happened" so I called him. He said his wife needed a restroom break so he accelerated through a stoplight before slowing to turn into a gas station and the truck began to stumble. He continued to drive it home which was about 20 miles. He said it ran OK at speed, but ran really bad at lower RPMs like when he slowed for a stop sign or stoplight. He said that the oil pressure light came on at one point when it stumbled down to 100-200 RPM. When he got home, he pulled the codes and it had a P0014 but no misfire codes. From what I find online, that would indicate advanced timing (bank 2/passenger side) like the VCT was stuck advanced which seems to go with the symptoms... he accelerated through the intersection which advanced the timing then it stayed advanced when he let off the accelerator to turn into the gas station. If the VCT solenoid stuck open, it would also explain the drop in oil pressure, or that could just be due to extremely low RPM. From what I understand, he later continued to run the engine in his driveway as he tried to diagnose it.
The next day (Friday), he said the problem with the truck was "now completely different". The previous day it was fine at speed and terrible at idle... and the next day it was fine at idle and terrible when given any gas. He also said that the engine had a terrible rattle like the timing chain was slapping around AND water was now leaking from behind the harmonic balancer. My thought was that it still had a timing issue, that VCT related low oil pressure could cause the lifters to rattle, and now maybe we had a coincidental water pump failure... but he said he thought it was catastrophic failure. He said he would look at it on Saturday.
His final conclusion:
I did not hear from him on Saturday but he messaged me yesterday (Sunday) and sent pics of an oil filter with metal particles in it (shown at the end of this post). He said the particles are not magnetic. He said the timing chains were good but he didn't send any photos of the timing chains or any pics of the disassembled engine. He said he scoped the cylinders and all of the cylinders look fine other than the one I replaced the valve spring on. He said that he believes that the cylinder I had replaced the valve spring on was damaged by the piston slapping the valve. He sent the following pic to show where the valve hit the piston head and made a dent (I circled it in the photo below). I told him that I thought the dent was too far from the relief indentation in the piston head to be caused by contact with the valve and that I do not believe that the valve would have later sealed had it been slapped by the piston. I had also scoped the cylinder after my repair and saw nothing. Note that the small "dent" circled below was actually visible in the scope photo that I posted in my valve spring repair thread. After I said the dent is too far out of path to be related, he said the cylinder wall next to it also has a discolored stripe near the "dent" proving it is an issue. (That stripe looks like an oil drip to me.) His conclusion was that the truck I sold to him was a "ticking time bomb even if I didn't know it" as a result of the broken valve spring that I had repaired.
I went online to find a photo of the piston's surface and found that the "dent" is from the factory and would appear on every piston in the truck. It occurred to me that earlier, he said the other cylinders were fine and it was just the one I worked on that was messed up but he did say "the cylinders were fine"... he did not say "the pistons were fine". It just seems like he would have noticed that all the pistons had the "dent" since he focused on the "dent" as evidence that the piston hit the valve and he made it a point to say that he had looked at every cylinder and they were all fine. He did not send photos of any other cylinder.
I sent him the eBay photo showing that the "dent" is a factory feature on the piston and he accepted that it indeed appears to have come from the factory like that. He said that he believes that the piston in the cylinder I worked on has a piece of the piston's surface broken off and the broken piece of piston damaged the cylinder wall. He sent the photo below (zoomed in version of the earlier photo). He said that he still believes that the cylinder that I repaired is the root cause for the engine's failure. He thinks the cylinder wall was getting shaved down from the damage caused by the valve or broken piston or something? and the truck made it a few hundred miles before the shavings damaged the bearings. I do not see a broken off piece of piston in the photo. In the zoomed out photo earlier, the dark spot looks like maybe a puddle of oil. I also do not see massive cylinder wall damage.
My take:
I discussed it with a couple of people who both said the same things: "Have you confirmed that the truck really is dead?" "How do you know which cylinder he is showing you?" The guy seems like good people and I'm inclined to believe it when he says that the engine is toast. He is well over 3 hours away from me so I just have to take his word for it. Obviously I gave no warranty on the truck.
He financed the truck and hasn't made a single payment since it broke down on his way home. He tells me it has suffered a catastrophic failure and I FEEL ABSOLUTELY TERRIBLE for him. I assume from his messages that he wants to tie this presumed catastrophic engine failure specifically to that valve spring break, perhaps to say that the truck had a fatal pre-existing condition prior to his purchase. I feel like he is really stretching to make that connection.
The early symptoms on his drive home seemed to be VCT/timing and then he continued to drive it for 20 miles after something failed which certainly couldn't help. The P0014 indicates that the initial issue led to the VCT being advanced (not retarded) and this is the opposite of a low oil pressure condition that could be caused by a VCT intake clogged with metal particles. The P0014 indicates a passenger side timing issue and the valve that I repaired is on the driver's side. The truck ran strong for ~400 miles after the valve spring was replaced, mostly short distance trips with many stoplights so a lot of time also spent running and idling. I am not sure how long an engine will let go if a broken chunk of piston is scraping the cylinder wall but we are talking a 4 stroke making millions and millions of revolutions over that time and I don't see the damage to that cylinder wall in his photo. I have sympathy/empathy and want to help the guy, but I also want to see if anyone else has thoughts on this?
Here are the rest of the photos that he sent. I also have a video of him dumping the oil filter (has shimmer in it) and a video of the water leak in which the truck can be heard running and it sounds like it idles OK. I will post them as soon as I move them from my phone. I don't think he has sent any other photos. The photos are tight to whatever he wanted to show me, do not provide much to go on, so mostly this rests on his description of events and what he is telling me.
6/8 I know this is crazy long and I made some edits for clarity.
ERICB100
ERICB100
Florida
Here is the audio/video of the engine running to show the water leak. Engine seems to idle OK. It looks like it could be water pump to me, but he thinks the water is coming through a hole in the block due to the catastrophic failure. I asked him if he scoped the water leak but hasn't because "that is the least of his concerns right now".
View attachment 1000011082.mp4
ERICB100
ERICB100
Florida
Here is the video of the oil filter being dumped. I cannot see the outside, but the oil filter I had on it was a Motorcraft (FL-820-S?). Again, I trust the guy that this is my oil filter. Note that there is only 400 miles (or less) on this since I changed the oil. Note that there is no milkshake, so no water in the oil.
View attachment 1000011120.mp4
EricM
OHIO
I wouldn't buy his story for one second. He was probably flogging the shit out of it.
You disclosed everything up front. They took a gamble on a used vehicle and lost.
I'd tell him, sorry buddy, but when you signed the title and drove off- it 100% became your problem.
ERICB100
ERICB100
Florida
I had sold the truck to him on Thursday for $15,000. Last night he is telling me that the truck needs a $10K engine and he does not know how he wants to proceed. About an hour after I started this thread, he said for a $1500 partial refund he would call it even. My GF had wanted me to sell it to Carvana all along and she was mad about the whole thing (I had sold it on her behalf and gave her the money). She wasn't happy. He wasn't happy. I was catching it from both sides so I gave him the money. It was worth my sanity to close the book on this. My friends think I got played. Yes I was not legally or financially obligated in any way, but I'm a decent human being. If the engine is blown, $1500 is giving him a band aid for a bullet wound.
1BAD454SSv2
HELL I ZONA
He never did a compression check on suspect cylinder , if low a leak down test? If piston hit valve it would of bent and there would be a dead hole , and you would know it . I don't know man everything on these 6.2 are solid except valve springs and oil pump only if your supercharged . You would really have to beat on it to hurt something even the 6r80 trans can take on lot on these . Something fishy , but stuff happens with 250k+ on the clock , once it is bought they own it .
04Ram2500Hemi
It's Just a Username
Western Montana
You’re a better person than me. You sold a truck that had over 200,000 miles and disclosed everything. The you gave him $1,500 because of your conscience. Close this chapter of your life and walk away my friend.
ERICB100
ERICB100
Florida
I'm sure you don't mean it this way, but giving him the money to clear my "conscience" seems like it would imply that I was responsible or I had done something wrong and felt guilty. That couldn't be farther from the truth, but I do think I know what you mean. Yes, I felt bad for dude and his very large $15K paperweight.
In all absolute honesty, I disclosed 100% of what I knew about that truck's history to the guy including all the threads I started on here. He could be reading this one too. I gave him all the receipts for parts/service that I had including those found in the truck, and those provided by my GF's ex by email... I printed out those out. I put all of the receipts in a packet. I sent him a ton of photos/videos showing him the good and bad of the truck before he ever drove down. I gave him ample time to inspect it when he got here. I even went into the house and left him alone with it for a while with the keys/while it was running. He test drove it for 13 or 14 miles with me and his wife. There was nothing left to do or say. AND I am 100% confident in the work that I did to the truck including the valve spring replacement. He was 100% FULLY informed. If something shady happened (and I am not saying that it he got shady and there is plenty of metal in the oil filter photos that he sent... but the truck was also still running fine in the video that I think is water pump weep hole leakage... ), either way karma is an MF'er. At least I'm on the good side of that.
My friend had asked "did he try to haggle the price?" and I said "the way he repeatedly harped on some of the flaws, he kinda sounded like a lowballer but I let him know that the price was firm before he even made the trip". He said "well, maybe dude decided to haggle you after the fact".
ERICB100
ERICB100
Florida
I'm 100% certain that the piston did not hit the valve. No way the truck would have run flawlessly for 400 miles. I had even used a leak down tester when I changed the valve spring and it sealed as expected. There is no evidence that he found anything to the contrary.
i am not aware of him doing compression testing or leak down testing. The only tests I am aware of:
  • He says he heard rattling sounds "like a loose timing chain"
  • He says the engine is stumbling when he gives it gas (previous day it stumbled at idle)
  • He found non-magnetic metal in the oil filter
  • His code reader found P0014 (advanced timing on passenger side)
  • He saw water coming from behind the harmonic balancer
  • His conclusion: catastrophic engine failure that was a direct result of the valve spring break that I repaired in April
I can't say how much metal is normal in an oil filter, I can't even confirm that was my oil filter he cut open and dumped (but I do assume/believe that it was). I don't have the truck here to look at, but I still feel it could be VCT related as the P0014 would indicate:
  • Thursday: ran fine at speed and stumbled at low RPM = VCT stuck advanced which also drops oil pressure and causes lifters to rattle
  • Friday: ran fine at idle and stumbled with acceleration = VCT closed on its own and is now stuck retarded
If that truck were still at my house I would take a look at the VCT, and if I got it running good, I would change the oil filter and run it some more to see if there were any shenanigans. I'd also take a look at the weep hole in the water pump because it would take only 15 seconds to confirm it's not a hole in the block.
Meat2022
Army Supporting Member
Alabama
Youre a good man, truly cool of you to give him any money back, good heart for sure, glad we have people around that have empathy even when its not your issue. If you open a car lot let me know lol, wish more dealers had some give a damn and care in them
ERICB100
ERICB100
Florida
I would say to bad so sad. Not your issue. Over 250k so it’s used and probably tired. He financed it?
Yeah, he financed the full amount. I think Navy Federal Credit Union? It would be a real kick in the nuts if the check was fake or something. I signed the truck over to him and Zelled him $1500.
ERICB100
ERICB100
Florida
My GF's 22yr old daughter overheard me discussing the truck saga and she said "If I bought a car and it died on my way home, I'd hope the seller would help me out". She was the only one I spoke with that put herself in the other person's shoes. Everyone else said "too bad, as-is, done deal". Well, my GF didn't say that... she said "I told you to sell it to Carvana" and "Resolve it however you want and let me know." (The $1500 came out of her pocket. It was her son's truck that I sold and she needed the money to cover his replacement car. The refund leaves her short.)
OKflyswatter
Oklahoma
If I could choose neighbors, ERICB100 would be one! Seems like a legitimately good man.
101,289
60,424
HC FabWerks
