Pulsing feel
Gsteve
While pulling away from a stop , very slowly , very light throttle . As it goes thru the first 6 gears I feel a very light pulsing or mild shudder . Today my passenger asked if we were running out of gas. I was surprised he felt it. It doesn’t happen with heavier acceleration or while cruising. Almost feels like a torque converter not locking up. Any thoughts ?
W0n70n
C Springs, CO
I'm assuming it's an ecoboost and there's a possibility that you have something going on with wastegate/blowoff/recirculation valves that's causing the engine to surge under light load that you wouldn't otherwise see, if you're tuned you could try going back to the stock map and see if that clears it up.
There's also a possibility that you have a slight vacuum leak somewhere causing the wastegate/blowoff/recirculation valve to do weird stuff (I don't know how the ecoboost system is setup specifically, just experience from other turbo vehicles).
W0n70n
C Springs, CO
If you have a smoke machine I would do that to check for vacuum/boost leaks, or pressure test the system, then check wastegate/blowoff functionality. Throttle position sensor operation, throttle body operation. It sounds like a vacuum issue to me since it's better when the truck wants to make more power (get out of vacuum and into boost faster) but I unfortunately don't know that truck specifically, hopefully someone who's more familiar can jump in that knows more specifically what's happening.
G
Gsteve
Not far off :). You know when your brake rotor is warped ? It feels like that. It so subtle that I don’t want to take it to the dealer because you know they will say “
Could not reproduce compliant “
juliolopez
CA
may be do a transmission service? just a simple drain and fill and filter change. Refill with proper fluid level.
G
Gsteve
I did a full fluid change in spring. After much searching and YouTubing . I found a product called Instant Shudder fix. It’s a friction modifier that has 100s of positive feedback and zero negative feedback. I’ve ordered it and will install on Friday
W0n70n
C Springs, CO
I would suggest doing a little more investigating and troubleshooting before adding any random mechanic-in-a-bottle products into one of the most expensive components on your truck.
James O
Lubbock Texas 79407
My 24 surges a little when cold and slowly accelerating. Its done it since new. My wife wanted me to take it in and I told her they will just say its normal operation, but I think Ford installed a bucking Bronco engine accidentally.
McCarthy
Canada
Mechanic in a bottle into a 10R80 virtually guarantees slip. It's a friction modifier in a transmission that is extremely sensitive. I would confirm fluid level and monitor.
G
Gsteve
Too late. 100s of positive results can’t be far wrong. I’ll report back soon
McCarthy
Canada
You're missing my point. 100's of positive reviews in random transmissions, likely old simple ones? Likely.
Most definitely not 100 happy 10R80 customers who used mechanic in a bottle.
101,310
60,412
hugecrankfonz
