Skyhigh18
What driving mode do you put your truck in? Not that I'll be doing it much, but if it ever comes up.
Why 4wd hi instead of 4wd low? Seems like the latter would be better on the transmission. I agree with not turning the wheels when doing this, especially on dry ground.Whatever the situation calls for. Do NOTput it in rock crawl
Mode pulling someone out a ditch on dry pavement, or pavement that is patchy dry/ice/snow unless you’re certain you can keep your wheels straight & have no reason to turn. I’ve yet to do so in my Raptor, but the majority of times I’ve pulled people out w/ previous GM trucks it’s during snow storms or on windy mountain/country roads in VT/NH skiing. Unless you’re pulling another big ass truck or suv, I use 4wd hi go slow at first until there’s good tension on the recovery strap then go for it & tank em out!
Be careful w/ chains. I don’t recommend using chains for light duty vehicles.
Agreed.Why 4wd hi instead of 4wd low? Seems like the latter would be better on the transmission. I agree with not turning the wheels when doing this, especially on dry ground.
Probably, but expensive.Would this be preferred instead of using the factory tow hooks?
https://www.amazon.com/dp/B07BB24MFQ/?tag=fordraptorforum-20
Not necessarily. The weight rating on your hitch is going to be less than the tow hooks. If it's just a straight pull with little to no resistance it would be fine. If the pull requires a yank to get them out probably not. The hitch is designed for the pulling weight to be directly inline. Anything offset is going to create forces that the hitch is not designed for. The tow hooks attach directly to the frame and are intended for offset loads.Would this be preferred instead of using the factory tow hooks?
