Who would want this tiny Bronco II they weren't that great back in the day and doesn't seem any better now.
Bring back the full size Bronco with a real engine!!!! (V8 that is!!!)
I loved my 84 Bronco.
As I’ve chimed in numerous times to point out Ford does not care much about V8 engines, they’ve never been the greatest @ building em, & every day that passes that becomes more true.
What You really want is your old ‘84 Bronco resto-modded.....& in that case you’d probably wind up w/ a proper Chevy V8 these days, but that’s another story.
If the next Bronco is based on the ford ranger that “tiny Bronco” if it its anywhere close to the dimensions of a regular Ranger 4x4 will most likely weigh about the same as your old Bronco (maybe 250-350 lbs lighter), it’ll probably sit just as high & be just as wide & probably a little longer. Will certainly tow more while packing much more power (probably close to double on both counts)
Tell me more about this big bronco you used to have again?
