Projector HID lights
Discussion in 'Ford Raptor Lighting Modifications Forum [GEN 1]' started by whtrapta, Jan 30, 2011.
Sponsored By: KC HiLiTES
  1. swoop1156
    swoop1156 FRF Addict
    3,291
    285
    Dec 14, 2010
    Honolulu, Hawaii
    Yeah, but that's a nice built in feature with motors, servos and electronics. Anything is possible depending on your checkbook, but I think that would be a bit overkill for us.
    For the cost of doing something like that -- you could just get some LED's that blind people like I have.
    [​IMG]
  2. pfbz
    pfbz Member
    15
    Jul 7, 2011
    Projector retrofits are definitely the way to go if you want to improve the stock headlights. Vastly better spread and cutoff than doing a HID bulb in the stock reflector. And from what I've read, most of the complete projector (non hid) headlight replacements have crappy lenses, and are actually worse than the stock headlights!
    Retrofitting in decent quality HID projector lenses, bulbs, ballasts seems like the best solution.
    There's a HID projector retrofit kit group buy going on right now for F150 owners. 25% discount if we get 25 or more kits ordered.
    This is a do-it-yourself deal, but with the latest kits, it seems much easier than the old methods of retrofitting. Little or no dremel work, adapter plates that line things up. Still have top split your headlight shells with some heat though.
    I have no personal affiliation with the retrofit source. Discount code is F15025 (case sensitive), more details here.
    Here's an idea what retrofitted F150/Raptor headlights look like:
    [​IMG]
    Different style trim rings are available, and some paint their reflector lenses black...
    [​IMG]
    These lights were done by a custom retrofitter, but at about $1,000 a pop for the custom guys (vs. $220 or so DIY), I'm going to give it a try myself.
  3. Viper
    Viper Full Access Member
    231
    Feb 16, 2011
    Vermont
    Here ya go Birdman... to complete your murked ensemble...
    BTW... These are sweeeet!!!!
  4. LEGORAPTOR
    LEGORAPTOR Full Access Member
    31
    479
    11
    May 19, 2011
    Deep South Texas
    I went on "theretrofitsource.com" page and wasn't sure what kit was for the raptor and what options go with it nor what would be the best choice.... help
  5. Raptor Retrofit
    Raptor Retrofit HID Specialist Supporting Vendor Supporting Member
    42
    1,967
    1,173
    Jul 22, 2010
    NY
    Hey man, I put the Morimoto mini H1 in mine but that was for a recon headlight, pretty sure it will still work for stock. Im painting the faceplate right now and doing a mock up, will have a write up on the install out tomorrow.
    If your retrofitting the stock headlights call TRS and talk to Matt, the guy knows everything about retrofits. Basically you want something thats end fits through the H13 bulb opening of our stock headlights and a shroud that will work with it. You may have to do some cutting to get it to fit.
    The one in the pic above was done by pro's, looks like they custom made a piece to fit between the headlight and the shroud.
  6. LEGORAPTOR
    31
    479
    11
    May 19, 2011
    Deep South Texas
    THX Ducati... Yea I just bought the recon headlights on ebay a few hours ago... and wanted a good bulb for an awsome beam of light. I will go with the Morimoto mini H1 then when I get the headlights. thx a lot, post the pics when available. :peace:
  7. Viper
    231
    Feb 16, 2011
    Vermont
    Duc...
    Pics and text please.... Retrofitting HID, a mod we all can relate to... Good luck and let er rip!!!
    Viper
  8. pfbz
    pfbz Member
    15
    Jul 7, 2011
    The stock Raptor lights are the same as regular F150 lights... The FX4, Harley, and Raptors come with black trim instead of chrome, but otherwise the same.
    The easiest kit to install is going to be the MH1 kit. Group buy discount at TRS is good through Aug 15th
  9. Raptor Retrofit
    42
    1,967
    1,173
    Jul 22, 2010
    NY
    Bit of a delay on my project. Mounted the base and flipped them on to start aiming and noticed some smoke starting were the bulb contacts the projector, when I put the bulbs in they went in a little tight. TRS is closed on the weekends so I cant call but after doing some reading I noticed they recommend 35w bulbs, Im running 55w. Ordered 35w bulb and ballast 2nd day air so hopefully up and running mid next week.
    They turned out pretty sweet though. I color matched the face plate, tux black. New ccfl's and led's and threw some side emitting led's in. Stay tuned...
    Thanks pfbz, used the discount code and saved 45 bucks on the bulb/ballast. :waytogo:
  10. Viper
    231
    Feb 16, 2011
    Vermont
    Sweet... Can't wait for the final upload....
Share This Page
