Projector HID lights
Discussion in 'Ford Raptor Lighting Modifications Forum [GEN 1]' started by whtrapta, Jan 30, 2011.
Sponsored By: KC HiLiTES
  1. whtrapta
    whtrapta Ostrich Wrangler
    27
    5,489
    911
    Jan 17, 2011
    Bolivar/Springfield, MO
  2. BIRDMAN
    BIRDMAN Birdministrator Staff Member
    12,906
    6,102
    May 16, 2010
    Boston
    You have to put your headlights in an oven or use a heat gun to split the lens off the headlight housing. it's a lot of work and you can screw it up easily if you scratch the lens or get any gooey silicone on the lens while you're taking them apart. not worth the hassle IMO
  3. whtrapta
    27
    5,489
    911
    Jan 17, 2011
    Do you just have regular HIDs?
  4. CineSLR
    CineSLR Roaming Shutterbug
    1,539
    449
    Mar 17, 2011
    New Orleans, LA
    There is a company here (in New Orleans) that does retrofits that I will be using to do my truck. If your interested I could see if they are interested in doing a group buy...? They do everything from Q45 Projectors, Custom Painting, ELWire to strobes to whatever you can dream up!
    I'm going to be going with a single BiXenon (probably TSX projector) with a black bezel and strobes (off road/parade use only!).
    My business partner did some photo work for them a year ago or so...
    http://www.flickr.com/photos/syf0n/sets/72157605262196090/
    [​IMG]
  5. CineSLR
    1,539
    449
    Mar 17, 2011
    New Orleans, LA
    That said, if your up to the task I would go for it and do it yourself. You will save a lot of money if you do it yourself...
  6. trolls56
    trolls56 FRF Addict
    36
    1,257
    38
    Jan 28, 2011
    Macomb,IL
    I'd be interest let us know what all you find out.
  7. ShiftyCapone
    ShiftyCapone Full Access Member
    128
    6
    Mar 9, 2011
    Detroit, MI
    Very interested....Keep us posted.
  8. Spider-One
    Spider-One Full Access Member
    31
    241
    20
    Nov 22, 2010
    NT, Canada
    I am considering doing this myself, the only issue I have it with adjusting the headlights later on. Even with some smaller loads in the bed I need to move the headlights up quite a bit so you need to be able to both seal up around the back of the projectors and maintain flexibility so as not to break the seal. Could always mount the projector to the stock reflector but then how do you maintain flexibility in the back for load adjustments...
  9. CineSLR
    1,539
    449
    Mar 17, 2011
    New Orleans, LA
    Dont keep the wire taught and use a rubber grommets is what I would do. Maybe someone with more experience can chime in.
  10. whtrapta
    27
    5,489
    911
    Jan 17, 2011
    IDK my last vehicle you could adjust the light height from inside.
Share This Page
