Pro comp traction bars
Jr raptor
Virginia
Good morning all ,
does anyone know the part numbers or what vehicle to order the pro comp traction bars for as they don’t have a listing for the gen 1 raptors and I’m tired of the axle wrap and wheel hop . Thanks everyone in advance .
Drswiger
Is your truck lifted or larger tires? Shouldn’t have a big axle wrap problem if it isnt
xrocket21
Maine
Anyway.... Deaver +3's pretty much solved my axle wrap issues. I didnt get wheel hop drag racing on pavement or dirt. like none at all.
TXRaptor
Deaver +2s if your truck is standard height and +3s if you want to go up an inch in the back. (With Deavers, you remove the factory block which eliminates the axle wrap)
Both choices will solve your problems and make the truck ride better all the way around.
pbtjrlmrt
Oregon
Good morning all ,
Get the KHC Torque Arm and forget about Deavers or anything else till you have a situation where you need them. Guys go straight to Deavers as if it's their religion for some reason when in reality the KHC Torque arm is all you need for wheel hop/wrap improvement without messing up the stock handling characteristics...which is what you paid up for in the first place. The benefits of deaver and other leaf spring packages are measurable and beneficial but totally depend on what you are trying to accomplish in your particular application. The KHC Torque arm will provide benefit no matter what else you're trying to achieve. It's kind of a no brainer mod with huge benefits as opposed to the deavers that require thought and care.
Sozzy12
South Idaho
Got a link?
Wfo
Syracuse
The Khc torque arm is an excellent design. Deavers are a huge improvement! With deavers the back doesn’t skip on bridge expansion joints or studder bumps off road.
