PRO COMP LED lights
RSiWORKS
S.C.S. Michigan
EXPLORER LED LIGHTING
The next generation of high performance lighting systems has arrived. Pro Comp Explorer lights are designed for the off-road enthusiast who demands the best. After nearly 20 years as a premier source of off road lights, Pro Comp is again lighting your path with the most advance lighting systems ever offered.
New LEDs and HIDs join the existing line-up of dependable halogen lights to provide a broad selection from which to choose. These new lights feature state-of-the-art construction and industry-leading features to handle extreme off-road abuse without a flicker.
R
RSiWORKS
S.C.S. Michigan
2X2 SQUARE 5W LED FLOOD PAIR $139.99
Part #EXP76406
images.ashx
2X2 SQUARE 3W LED SPOT PAIR $139.99
Part #EXP76407
images.ashx
Single Row
SR6 7.3 INCH SINGLE ROW LED FLOOD/SPOT/COMP PATTERN $189.99
Part #EXP76306
7.625 X 1.164 X 3.327 inches over all, 21.6 Watts, 1920 Raw Lumens
images.ashx
SR12 SINGLE ROW LED FLOOD/SPOT/COMP PATTERN $256.99
Part #EXP76310
13.625 x 1.614 x 3.327 inches overall, 43.2 Watts, 3840 Raw Lumens
SR24 SINGLE ROW LED FLOOD/SPOT/COMP PATTERN $453.99
Part #EXP76320
25.625 x 1.614 x 3.327 inches overall, 86.4 Watts, 7680 Raw Lumens
SR36 SINGLE ROW LED FLOOD/SPOT/COMP PATTERN $855.99
Part #76340
37.625 x 1.614 x 3.327 inches overall, 129.6 Watts, 11520 Raw Lumens
SR48 SINGLE ROW LED FLOOD/SPOT/COMP PATTERN $1026.99
Part #EXP76350
49.625 x 1.614 x 3.327 inches overall, 172.8 Watts, 15360 Raw Lumens
Double Row
DR6 DOUBLE ROW LED FLOOD/SPOT/COMP PATTERN $256.99
Part #EXP76406
7.75 x 3.23 x 3.51 inches overall, 30 Watts, 2400 Raw Lumens
images.ashx
DR12 DOUBLE ROW LED FLOOD/SPOT/COMP PATTERN $342.99
Part #EXP76410
13.75 x 3.23 x 3.51 inches overall, 60 Watts, 4800 Raw Lumens
DR24 DOUBLE ROW LED FLOOD/SPOT/COMP PATTERN $600.99
Part #76420
25.75 x 3.23 x 3.51 inches overall, 120 Watts, 9600 Raw Lumens
DR36 DOUBLE ROW LED FLOOD/SPOT/COMP PATTERN $1113.99
Part #76440
37.75 x 3.23 x 3.51 inches overall, 180 Watts, 14400 Raw Lumens
DR48 DOUBLE ROW LED FLOOD/SPOT/COMP PATTERN $1368.99
Part #76450
49.75 x 3.23 x 3.51 inches overall, 240 Watts, 19200 Raw Lumens
IRONMAN
Well-Known Member
MICHIGAN
LIMITED TIME OFFER
For the Month of May, I will be offering 25% OFF all these light bars.
While supplies last!
76406
76410
76420
76450
76306
76310
76320
76340
76350
76440
