Pressure washer recommendations
Discussion in 'Ford Raptor Cleaning and Detailing Forum' started by LaceyPark, Mar 25, 2018.
Sponsored By: Adam's Polishes
  1. LaceyPark
    LaceyPark Member
    11
    10
    Jan 20, 2018
    Camp Hill,PA
    Looking for a good Pressure washer for the truck and some light around the house work (cleaning brick patio / siding ), but 99% of the time it will be used for washing the truck. Maybe something $200 or under?
  2. Adam Ratatat
    Adam Ratatat Full Access Member
    78
    28
    Jan 1, 2018
    SoCal
    I bought a 1750 PSI pressure washer from Harbor Freight and will be busting it out tomorrow on the truck and to finish cleaning the old shocks I am sending to Forged Off-road. I will let you know if it does the job. The Pressure washer was $99.00 on sale.
  3. 2014RubyRed
    2014RubyRed FRF Addict
    50
    8,851
    6,903
    Jan 11, 2015
    Galesburg, IL
    ineedaBubble likes this.
  4. ineedaBubble
    ineedaBubble FRF Addict
    1,770
    452
    Dec 8, 2016
    Swansea,MA
    bruiser likes this.
  5. reaper1441
    reaper1441 Full Access Member
    31
    349
    178
    Feb 4, 2018
    the Ryobi with the Honda engine is pretty awesome and available at home depot. adding swivel fittings to mine this weekend because the hose is stiff.
    waddellw likes this.
  6. waddellw
    waddellw Full Access Member
    447
    117
    Feb 5, 2015
    Mississippi
    I was nervous to pick up the Ryobi washer from home Depot for 300 or so dollars on sale but decided on it and it's in season 2 now with no issues. No paint-ripping pressure but it's solid with a Honda motor. Auto idle is the best too I love it.
    Your friend has shared a link to a Home Depot product they think you would be interested in seeing:
    You kinda get what you pay for-
    Below 300
    Electrics mostly, not good units, terrible output and not too dependable in my experience.
    300-500
    Fine pressure washers usually, not the greatest ever but worth it.
    500 up
    Commercial grade units mostly.
    I recently picked up an mtm foam cannon and it works amazing with the unit. Foam everywhere. The pic below is on an '18 leadfoot. The soap had been on there for a few minutes before I thought about snapping a pic but trust me it was very thick at first before it all started sheeting off. [​IMG]
    Sent from my Pixel XL using Tapatalk
    [​IMG]
    [​IMG]
  7. RaptorMaryland
    RaptorMaryland Full Access Member
    293
    87
    Dec 24, 2017
    Maryland
  8. TheWolf
    TheWolf Full Access Member
    45
    966
    1,346
    Nov 15, 2013
    Spokane, Washington
    While many people like the power of gas at a decent price point, after using a higher-end electric, I would never switch back. The biggest plus is having the auto on-off which turns the motor off when the trigger is released. No idling and no turning it on and off. It is the AR Blue Clean AR630-TSS-HOT. This unit can also be ordered for a lower cost without the hot water seals, but using warm water for winter washing is nice.
    I had the MTM Cannon and used it for a couple years, then found the Adam's Cannon made better foam with my pressure washer. Also, at $144.49 with the discount it is less than the MTM.
    https://adamspolishes.com/adam-s-foam-cannon-snub-nose-combo.html
    [​IMG]
    Sent from my SM-N950U using Tapatalk
    NM156 and RAPTORSV like this.
  9. RAPTORSV
    RAPTORSV FRF Addict
    2,586
    1,308
    Sep 15, 2011
    S. California
    I have a question. Do you know what fittings or where to get that will turn the hose out of the pressure washer into a quick connect? I have quick connect for the garden hose, but not for the pressure hose. Also how do you connect the Adams snub nose to the pressure hose? The hose for the pressure washer is threaded each end, the quick connect is at the end of the wand that came with the pressure washer, not the end of the hose.
    ---------- Post added at 11:36 AM ---------- Previous post was at 11:30 AM ----------
    I would love to get the snub nose, but have no way to connect to the hose. I have searched online, Home Depot, Lowe's, etc, but no luck. The wands that come with a pressure washer attach the same way the the pressure hose connects to the pressure washer. No one seems able to answer this question.
    ---------- Post added at 11:41 AM ---------- Previous post was at 11:36 AM ----------
    Even the Adams website says couplings are sold separately, but no indication of where? So this will defiantly hurt sales, it is preventing me from purchasing.
  10. TheWolf
    45
    966
    1,346
    Nov 15, 2013
    Spokane, Washington
    The Adam's gun has a 3/8" male quick connect, so you need a 3/8" female socket quick connect coupler for your hose.
    The variable is what kind of threads are on your hose end. Many hoses are 3/8" NPT threads but they can also be 1/4" NPT or M22.
    You can find these quick connects at Home Depot or Lowes which makes it easy to get the correct one by taking the gun and hose with you. Or if you know what threads are in your hose you can order one online.
    Once you get the gun, you can also take the male quick connect off and if the threads are the same as your hose, just take the quick connect to the store to match it up.
    https://adamspolishes.com/shop/specials/foam/adam-s-foam-cannon-snub-nose-combo.html
    ---------- Post added at 12:22 PM ---------- Previous post was at 12:20 PM ----------
    Here's an example of a female coupler with 3/8" NPT threads.
    Forney 75129 Pressure Washer Accessories, Quick Coupler Female Socket, 3/8-Inch Female NPT, 4,200 PSI https://www.amazon.com/dp/B003X5PR8Y/ref=cm_sw_r_cp_apa_EUOVAb1AS55S5
Share This Page
