GEN 2 Powertrain Malfunction question
Discussion in 'Ford Raptor Problems and Questions Forum' started by JustDennis, Aug 24, 2020.
  1. JustDennis
    JustDennis Full Access Member
    61
    10
    May 13, 2020
    Upstate SC
    I have a 2017 802A SCREW with 33K miles. On 7/11, I was driving about all of a sudden got the wrench message and the Powertrain Malfunction error. I was just driving normally and had just left the house - maybe 2 or 3 miles. I turned around and came home. After searching on here and reading thru the threads, I disconnected the battery for about an hour and reconnected. The message was gone, the adaptive shifting was reset and the truck drove normally. I continued to drive until 8/15 when the message reoccurred while driving. Again, normal driving and I had been driving about 30 minutes or so. I reset again and so far back to normal.
    Here's my question(s) - has anyone else experienced anything similar and if so have you found the root cause? Secondly, I plan to take the truck into the dealer when/if it happens again. The truck still has the powertrain warranty and I want to get it noted. Hopefully they can find something. Is there anything else I should be doing or checking? Thanks for the feedback.
    Love the truck but hate driving anticipating a message any minute. My truck has been dynoed if that makes a difference.
  2. FordTechOne
    FordTechOne FRF Addict
    1,639
    2,011
    Jul 29, 2019
    Detroit
    When that message appears, there will be DTCs in one or more modules. Your best bet is to get it to occur and drive straight to the dealer or have it towed. Do you have any mods?
  3. JustDennis
    61
    10
    May 13, 2020
    Upstate SC
    I have a Whipple CAI, intercooler, Magnaflow full exhaust with downpipes and a dyno tune.
    I just checked the DTCs that were still stored since I hadn't reset them. They were:
    U0401 - Invalid Data received from ECM/PCM
    U0140 - Lost Communication with Body Control Module
    U0554 - Invalid Data Received from Accessory Protocol Module
  4. JustDennis
    61
    10
    May 13, 2020
    Upstate SC
    Update - I took the advice. Called the dealership and they suggested I get Ford Roadside assistance to tow it. They towed it to my dealer and I got a call back yesterday. The Service Manager just called and said the wiring from one of the O2 sensors was too close to the exhaust and the wires melted. The resulting short is causing the problem. It will take a couple of days to get the new O2 sensor. In the meantime, he is going to do the "fix" for the intermittent tailgate opening.
    Hope this fixes the issue. Makes sense to me
  5. Bowewelding
    Bowewelding Full Access Member
    175
    31
    Aug 13, 2017
    I have a 17 aswell and about a year into owning it from New I got the wrench light. Long story short, my dealer could not figure it out. After changing the harness from the trans to the pcm, an alignment, changing the abs module, the restraint module, and over laying a new wire under the passenger seat. The light still comes on with similar codes as your, (different modules losing communication). I requested a manufacturer buy back and they approved it. I turn it in this next Wednesday and then I'm shopping for a 2020 in Oxford white..im going to check the o2 sensor wire after reading this post though
    JustDennis likes this.
  6. JustDennis
    61
    10
    May 13, 2020
    Upstate SC
    So just got a call from the dealer. Truck is ready and he said it is fixed. Evidently the wiring to the O2 sensor melted and they also replaced the lead wiring harness it connects to. They put in the fix for the intermittent tailgate opening. I'm headed to pick the truck up and will report back after a bit.
  7. JustDennis
    61
    10
    May 13, 2020
    Upstate SC
    Update - Seems the O2 and wiring replacement has corrected the problem. No codes and the truck is running great and shifting smoothly. I really hadn't realized but a lot of the rough running and shifting I was experiencing must have been coming from the melted wires. Hopefully this has fixed the wrench/powertrain malfunction errors.
Share This Page
