Power washer??
jeremyespinoza
Need help deciding what power washer to get. Looking at Greenworks 2,000-PSI 1.2-GPM Cold Water Electric Pressure Washer or Sun Joe 2000-PSI 1.76-GPM Cold Water Electric Pressure Washer. I'm going to be using it to use the mtm foam cannon.
Hagasan41
Florida
I can't answer specifically about either one of those. But I can tell you to stay away from the Karcher brand. I had 2 of the K7 *** fail within 6 months. The first one begain leaking and replaced under warranty. It's replacement failed within a couple of months. IIRC, they were $270-$3XX each.
I had an older Greenworks that lasted about a year with regular weekend use.
I finally went all in and purchased a Kranzle 1122TST that i've had for over 2 years without issue. Paired up with the MTM PF22 and the older MTM Hydro cannon and it makes washing my toys a blast!
Raptize
I have had a Honda GC160 with the 5.0 pressure washer for at least 15 years. 2 or 3 pull strings replaced, the carb being cleaned a few times and the wheel fell of once. Starts with ease and run great all the time.
J
jeremyespinoza
How much are those Kranzle cost around? I heard good things about them
---------- Post added at 02:20 AM ---------- Previous post was at 02:20 AM ----------
Where could I get one
J
jeremyespinoza
No where would I go for that?
---------- Post added at 04:20 AM ---------- Previous post was at 04:19 AM ----------
I seen people on YouTube use electric with the foam cannons and looks like it does the job
crash457
I'm Batman
St. Louis, MO
MTM foam cannons are made for gas high pressure washers FYI. Won't work right with electric.
Not true. It works with any pressure washer between
1100-5000 psi and 1.8-5.3 gpm.
https://www.amazon.com/MTM-Hydro-Original-Professional-Adjustable/dp/B004GNZYY4
The even sell one withe a Karcher bayonett fitting.
http://https://www.amazon.com/MTM-Hydro-Professional-Adjustable-Bayonet/dp/B00EDSLVQC
I have used mine with a Karcher K3 and a K5. Works great.
