Power Steering Solution Ford F-150 SVT Raptor Power Steering Reservoir Upgrade
Discussion in 'ICON Vehicle Dynamics' started by ICONRep, Oct 17, 2012.
  1. ICONRep
    ICONRep Supporting Vendor Supporting Vendor
    387
    728
    Aug 17, 2011
    Riverside, CA
    [​IMG]
    Overview:
    After hours of testing and offroad abuse on the ICON Vehicle Dynamics Ford F-150 SVT Raptor we felt solution was needed to further improve the overall performance and function of the OE steering system. When pushing this vehicle to its maximum potential it was apparent that the factory power steering system would develop aeration and lead to a foaming of the fluid in the OE reservoir accompanied with a loud fluid whining or "growling" noise. These symptoms would ultimately lead to reduced life and performance of the steering rack. Power Steering Solution has developed a high performance billet aluminum reservoir that not only increases the overall fluid volume, but includes an anti-cavitation valve as well. The combination of cutting edge design and engineering has led to an easy to install bolt on reservoir upgrade that installs within 30 minutes, in the OEM location, with factory hoses and hardware. The CNC machined power steering reservoir also includes a threaded o-ring cap with a 12psi pop off valve to eliminate increased pressure build during extreme use conditions.
    Inline Power Steering Cooler Upgrade coming soon!!
    Key Features:
    • Direct bolt in replacement w/ no additional components required (additional fluid supplied)
    • CNC machined from 6061 aircraft grade aluminum
    • Threaded o-ring cap w/ 12psi pop off valve
    • Built in anti-cavitation valve designed to eliminate fluid ariation / foaming
    • Increased power steering reservoir fluid volume with increased flow
    • High end AN fittings for factory-like seal to OEM power steering lines
    • Made in the USA
    Tech Info:
    • Bolts on easily with basic hand tools
    • Includes additional fluid required for installation
    Kit Includes:
    (QTY - 1) - Fully assembled & ready to install PSS reservoir
    (QTY - 1) - Qt. PSS power steering fluid
    Installation Instructions
    ---------- Post added at 05:01 PM ---------- Previous post was at 04:55 PM ----------
    Will also be posting a first look at the cooler option tomorrow.....available next week!! Look for it.
    Link to Product on the ICON website
    COBRA90GT and iHaveGas like this.
  2. Yukon Joe
    Yukon Joe FRF Addict
    40
    18,308
    11,562
    Nov 16, 2011
    Oak Island, NC
    Is it really machined from a solid piece? That's a lot of chips to throw.
    The mounting looks unique, do you have any install pics?
    Looks sharp!
    Joe
  3. ICONRep
    387
    728
    Aug 17, 2011
    Riverside, CA
    Sure is.....6061 solid bar with a threaded screw on cap.
    Here is a pick of it installed on our Raptor
    [​IMG]
  4. Yukon Joe
    40
    18,308
    11,562
    Nov 16, 2011
    Oak Island, NC
    Since your already doing all that machining, you should put it on a lath and machine some radial fins into it.
    Joe
  5. SwampKing
    SwampKing FRF Addict
    32
    1,938
    264
    Apr 7, 2012
    Looks nice! I like the 12psi pop valve idea.
    '12 Race Red Raptor SCAB (Loaded to the max!)
    SCABS are faster!!
    '08 SeaDoo RXP-X Clockin' 80+ GPS
  6. BlueSVT
    BlueSVT FRF Addict
    2,047
    1,415
    Mar 10, 2011
    San Dimas, CA
    Man... that is SWEET.
  7. ICONRep
    387
    728
    Aug 17, 2011
    Riverside, CA
    We we are not finding that necessary at this point.....we made it through the last Outlaw Raptor Expedition Run (was a night run half of it and then day the second half) with not one issue or complication.
    However we will have the Power Steering Solution Reservoir with cooler available in the next week or so which will 100% eliminate any power steering over heating concerns. Here is the first look at the kit
    [​IMG]
  8. BlueSVT
    BlueSVT FRF Addict
    2,047
    1,415
    Mar 10, 2011
    San Dimas, CA
    If you want to put it through some real punishment on next weekend's "Land Rush 1000" event, I'm your man! ;)
    BTW, the Icon 3.0 shocks are working incredibly well so far on my Scab. More testing and tuning tomorrow, and I'll have a full write up posted soon!
    - Matt
  9. Yukon Joe
    40
    18,308
    11,562
    Nov 16, 2011
    Oak Island, NC
    I was thinking for some added cooling with only the res. change out.
    The cooler looks great, will it mount where the tranny cooler is?
    Joe
  10. ICONRep
    387
    728
    Aug 17, 2011
    Riverside, CA
    I will have the install photo's for you Monday or Tuesday. It mounts upward of the tranny cooler but not up against the radiator allowing good air flow for both. Upper bracket attaches to the core support locating it basically right below the hood latch to give you an idea.
Share This Page
