GEN 1 Power steering pump
Discussion in 'Ford SVT Raptor General Discussions [GEN 1]' started by Mjparsons, Mar 14, 2017.
  1. Mjparsons
    Mjparsons Full Access Member
    34
    82
    16
    Mar 20, 2016
    Rancho Santa Margarita, CA
    I'm started getting inconsistent steering feel in my truck recently. Sometimes it's stiff to turn the wheel and sometimes it gets very easy to turn. Could this be a pump issue?
  2. CineSLR
    CineSLR Roaming Shutterbug
    1,539
    449
    Mar 17, 2011
    New Orleans, LA
    Yes, first step is check your fluid levels...
    Sent from my VS987 using Tapatalk
  3. Mjparsons
    34
    82
    16
    Mar 20, 2016
    Fluid levels are solid. Now that I'm paying more attention it feels wobbly now if the steering wheel is centered, like theirs a little play left and right. But definitely feels firmer at times and easier to turn at other times.
  4. RDFTS
    RDFTS aka Rick Supporting Member
    12,460
    8,613
    Nov 10, 2013
    Southwest Missouri
    Check the rack too. Lift the front and grab the tire from 9 to 3 and see if the tie rod seems loose where is goes in the rack. Best to have someone hold the steering wheel. Had a similar issue and I had to move the boot on the tie rod out so I could see how it was reacting in the rack. Got the rack replaced under warranty.
  5. Mjparsons
    34
    82
    16
    Mar 20, 2016
    I'll have the rack checked out for sure. It's hard to tell what's causing it. Could be shocks needing rebuild, pump, or rack. Or all 3.
  6. Mjparsons
    34
    82
    16
    Mar 20, 2016
    Ok so I just had my pump replaced after having my steering get very stiff last week. It was leaking so they replaced it but my steering still feels stiff. Can't tell if it's supposed to be this way or if something is still in need of repair.
  7. AndysLog
    AndysLog FRF Addict
    1,120
    508
    Jan 12, 2017
    Moro IL
    not many components past that. steering rack then the end links.
  8. thearizonacowboy
    thearizonacowboy Full Access Member
    169
    116
    Feb 7, 2017
    Phoenix Arizona
    Anyone know why I would be getting random vibrations in the wheel? Turning in parking lots will do it. I've beat the hell out of it, jumped it maybe 100 times in a couple months and it hasn't gotten worse or better. Fluid looks fine and at the proper level.
Share This Page
